Nice trap speed...Similar results here. A tractionless 14.6@97 in my 66 'S' car but with the stock valves
Nice work Michael!I did some J heads for a future 360. Proceeding with caution I removed only enough material to have smooth slaggy/parting line free surfaces. (No hogging out attempts at 351 Cleveland sized ports) I polished the combustion chambers, exh bowls and exh ports much more than needed simply because I could and was actually having fun. They look like sterling silver. The intake bowl was blended (machinists cutter enlarged valve to a 2.02) Intake side was gasket matched and the pushrod pinch? I didnt measure but just removed a little bit of wall thickness. Intake ports and bowls final finish was with a coarse sandpaper cartridge rolls. The guides I maintained caution. Steve Dulcich achieved incredible numbers porting J heads but man it he removed alot of the Int valve guide structure.Hes ported tons of mopar heads and flows them- I didnt try to duplicate his valve guide work. I left the guides srtuctural length but rounded and contoured every square edge. There are very swoopy and impressive (To me). As some just stated- this is hot rodding when we DIY. View attachment 1715159640 View attachment 1715159641 View attachment 1715159640 View attachment 1715159641
Thanks ST. I had fun doing these with my 3/4 HP flex shaft Dremel.Nice work Michael!
We have had 'J' head issues with them going thin as per the cut head inside the intake port too.
'J' heads are brilliant and don't need to be 'HOGGED' they is good to start with!
STR
I’ve git the bowls cleaned up pretty good. I’ve scribed a 318 size gasket on the intake port. I think it’s 1.05” wide. My intake manifold is also that size. I can’t enlarge the port that much without breaking into the pushrod tube. If I leave it, it would be a pretty big mismatch. Not sure how to proceed
Hi DK,
I would grind the port inlet at an angle to meet up with thinnest point, inside the port entrance.
To get the port as wide as poss. you will need to buy or make an 'E' gauge.
I made my own with some 1/4 inch steel rod and a hobby welder.
The hardest part was making a swivel joint and I cut down an airline fitting with a 1/4 bore for this.
simple answer is NO.
Pushrod pinch(prp) is not as big of a restriction as it look. If your working on the short side radius (SSR), raising the roof, at the ssr and raising the roof at the intake/ head surface. THEN, the Pushrod pinch becomes a restriction. If you don't have a flow bench and can watch what happes, Don't Do It! If your not going to mess with the ssr, the prp, is NOT the smallest Cross Section in the head. there for, no cfm gain grinding on it.
Clean it up and leave it alone is my suggestion.........
looking forward to it.I did smooth the ssr a bit. I’ll try and post some pictures tonight
