moper
I'm not sure in the real world if you could get a set of 302 heads to run low 12's, unless the car is REAL light, hooks up perfectly, and is driven flawless.
I agree. 320s are good, but simply not THAT good...
Some Food For Thought !
408 cu. in. ...1 hp per cu. in....408 hp (4" stroke)(torque Monster)
360 cu. in. ...1.13 hp per cu. in.408 hp (3.580 Stroke)(medium Torque)
340 cu. in. ...1.20 hp per cu. in 408 hp (3.310 Stroke)(no torque)
318 cu in. ...1.28 hp per cu. in. 408 hp (3.310 Stroke)(no torque)
Which is most economical to run and easiest to achieve ?....Lee
I think the short 340 stroke is the reason why I have never been impressed by them.
If I want R's and longevity, I'll stick with my 318, if I want torque, I will go 360, or my favorite, 4" a 318..............
And also, in stockish form, I am not sure there is too much of a RPM-vs-Power output from the 340 to the 360. 3.31 with a heavier piston vs a 3.58 with a lighter piston, almost seems to balance out.
I have 302's with 1.88's on my 390. Makes wicked torque, but it is a truck engine, it never goes past 4800-5000. I would go big port if I was looking for that much power.
Apples to apples...........
Of course you cant compare a 7.2-1 360 to a 10.5-1 340. Thats not what I was saying.
Bah....... Not worth it.
If everybody stops for a second and thinks, even though the 340 has a heavier slug, the stroke is what will get this engine spinning higher and quicker since the distance is shorter.
Add light weight pistons to it or ethier engine and the 340 is still going to spin up quicker and higher.
A longer stroke engine has to move the piston a greater distance and has an issue with piston speed witch has a speed ceiling limiting it to *** RPM's.
The next item in high RPM's is valve control which is the springs job.
You can make a 12 sec 318 very easily and it can be very nice to run on the street and run on pump gas.......you don't need the 360. Yes you can build the 360 to make more power for about the same money cause it uses almost all the same bolt ons but you already have the 318 and it's so much fun spanking people with a 318 cause they get pissed......no one gives the 318 any respect even mopar guys and it drives me nuts. First thing is tell me your budget. How much do you want to spend? Are you looking to use stock or Eddy heads? You want to run on pump gas or race gas? Are you gonna keep the car street legal?
