Val-Mike, If all goes well, I'll let you know the compresion differences of the 302 vs. Magnum heads on a teen. I have both.
I want to port the 302 vs. a standard Magnum.
The 302 port window will be opened up to 340/360 sizes. Very much like a Magnums head. The thing is a Magnum head flows very well for the window size. So does the 302, but it's window size is smaller and less. The 302 head can be ported well with a opening of the ports to a larger size.
This enlarging of the port window puts it on par more with the magnum head. And the performance potentail. Keeping the port window small on the 318 will be fine for most cases. If street bound only without a big care of max output, they'll be fine. In the end results and mods, it will be closer to a apples to apples compare rather than a small port vs. large port.
Save the one serious advantage of the Magnum, 1.6 rockers.
The cam I have in the car is a Crane, 218/226 @ .050 and lift is low. But this will also change later. A cam of this size can bennifit from a larger port window, in the right arena.
Engines have an area (Size regurdless) were a larger port will perform better to feed the engine and release more power. I am experimenting with this size cam. Previously, I would have said a larger cam, but I have been wondering if I can get better results with a smaller cam.
The car; '74 Duster, '79 stock short block 318, 904, 8-1/4,w/3.21's and suregrip. Stock tires on ralleys.
A total (Well, damn close) sleeper. A done on the cheap thing. While trying to extract better performance. How far I'll push it is a time will tell thing.
But for right now, it's going to be a few head and intake swaps with this cam and test it going to and from the track while checking out times.
