The Performer is beter. The LD4B isn't bad though. I have one. I think the ports are 360 large. I'll check later this eveing.
harrytoes said:Is there a big difference between the Edlebrock Performer and the Edelbrock LD4B?
The Performer is Not suggested for use on a 273,
I think the Performer will not flow well at low cfm,
speeds,whereas the LD4B is a Chrysler approved,and sold part,
that was made for the 273,and 318.
rumblefish360 said:Why would you think a performer would flow poorly on a 273 and or be out done by a older discontiued intake. Is it a C.I.D. thing?
I seldom if really ever see a company, like Edelbrock, go backwards in intake manifold design.
No, you can make the 2bbl. linkage work. Theres an adjustment on the swing arm of the tranny and you can use a nut and bolt with 2 washers up by the carbs arm to set it up well. Not a problem.harrytoes said:So if i go with the performer and get a perfromer carb(1406). I'm guessing that the linckage will be different than my carter 2bbl. What do I need to change, buy, or manufactor to make it work?
:salut:BJR Racing said:I have 5 or 6 sets to check and I'll put part #s with them.
BJR Racing
cavemanmoron said:if I knew before hand, what I do know, I would have used
1.88 intakes,
moper said:If your car has the original 318 (meaning '68?) 318, you already have smaller chambers than the 589s have. By a bit. '68-71ish 318s had smaller open chambers. I like to use them when I needs more squeeze on a newer LA...If you're looking for power, I would either use your exisitng heads, fit them with 1.88/1.609 valves, good valve job, springs, trim the guides, etc. and run them; or get a set of Magnum heads, have them done up, and run them. That would require a little more work, and parts, but I think they would be your best bet.
Yeah, been doing more reading, I think once I've dialed in my combo more (leaving the cam till last), I'll call one of the cam companies with the details for a recommendation and/or custom grind.moper said:I would choose a better cam than one made by Edelbrock if it were up to me.
Yep, I've got the How To books on both "Hot Rodding Mopar small blocks" and "Building Big Inch Mopar small blocks" that cover all the modifications to use the Magnum heads.moper said:And dont forget, with Magnums, you need AMC lifters, and drilled pushrods to keep the top end oiled. So if you can purchase just the cam, and then lifters, you'll be better off.
