340/360 manifold or manifolds to work in 64-66 abodies
FABO Welcome Wagon
  1. dazedand confused
    dazedand confused Well-Known Member
    155
    35
    Oct 3, 2010
    hollister mo.
    Local Time:
    4:18 PM
    I have a 65 dodge dart slant but the dart will be housing a modified 360 .All iI need is the drivers side Y shaped manifold . I was planning on using 93-95 jeep grand Cherokee 318 magnum manifold for passenger side. If I have to I with buy the 340 set but I can afford eBay prices? Anybody have these manifolds or manifold let me know and I'll see if my bugget will allow it thanks
  2. pishta
    pishta I know I'm right....
    18,270
    7742
    Oct 13, 2004
    Tustin, CA
    Local Time:
    2:18 PM
    ~$400 is about the min Ive seen 340 logs for, even here. Are you running an auto and manual steering? power steering is out. Driver is standard L shape, the early 340 passenger is the "branch" unless your RHD.
  3. krazykuda
    krazykuda Well-Known Member FABO Gold Member How-To Section Editor
    55,116
    20450
    Aug 20, 2007
    Orland Park, IL
    Local Time:
    4:18 PM
    Talk to member @Treblig
    He's an expert on manifolds and modifying them...
    However, be aware that the 64-66 a-body engine compartment is tighter than the later ones and therefore is more limited on exhaust choices... I don't think that the 68 - 70 340 manifolds will work in that car...
    • Agree Agree x 1
    • vntned
      vntned Well-Known Member
      1,298
      822
      Apr 28, 2012
      Gibsonville NC
      Local Time:
      5:18 PM
      They "work". I've got '68-'70HP manifolds on the 360 in my '64 dart. It has manual steering and a 4spd. It's a serious pain in the ass. In hindsight, I about wish I'd just run the early A 273 manifolds.
      • Like Like x 1
      • Treblig
        Treblig Well-Known Member
        6,318
        3468
        Oct 5, 2013
        South Texas
        Local Time:
        4:18 PM
        I know that a few FABO members run the late 60s 340 manifold on the driver's side (the 70s 340 driver's manifold is a different design) and the 96/97/98 Jeep Grand Cherokee manifold on the passenger's side. Mopar (Jeep) did make two different magnum passenger manifolds and I can post a pic of the correct one. If you buy the 360 magnum off of ebay you will pay between $40-$75 unless you can find one in the local savage yard. I have bought the correct 360 passenger's manifold for as low as $35. The 96/97/98 magnum manifold comes from the factory with a 2 1/8" exit hole which is just a little smaller than the 340. You can machine it out if you're careful. I don't know of any other large hole passenger's manifold that fits better or flows better. Be careful on ebay because unless you call the seller and verify the Hollander number you won't get the correct manifold.
        You can find a 60s driver's manifold here on FABO for around $200. The least you'll pay if $150 and the most will be $275 or so.
        treblig
