340 Build Final Combo. What Do You Think?
Small Block Mopar Engine
  1. ValiantKindOfGuy
    ValiantKindOfGuy Well-Known Member
    254
    53
    Aug 14, 2019
    Plympton Mass
    Local Time:
    8:43 AM
    055EE03E-7321-45DB-8DB2-4B4BF97B346F.png So after sleepless nights and pacing at work I have finally decided on my 340 combo. I’ve looked at almost every camshaft available off the shelf, made some calls for a custom grind but finally decided to go to my special place (my bench covered in cams) I decided on this obscure voodoo cam deciding to save the 250 and put it elsewhere. (pictures for specs) here is the combo.
    Short block came from a parts car-
    Speed pro heavy .030 flat top. .020 out.
    Stock rods with aftermarket bolts.
    Forged stock stroke crank. Windage tray and fab pan.
    10.1:1 static
    8.1 dynamic
    Top End-
    J heads 2.08 valves some mild porting (see my earlier post in the week for port pics)
    Air gap or tunnel ram haven’t decided.
    Holley 750 double pumper (not for tunnel ram)
    Exhaust- 1 3/4 long tubes into 3in X-pipe dumped at axles.
    Accessories- alternator and water pump
    (Electric fans)
    Extra info (chassis)-
    Car is 2900# without driver.
    4 speed (2.66 first)
    4.10 8.75
    Aluminum flywheel
    Aluminum DS
    McLeod clutch( yes I know)
    Let me know what you think. I’m ready to get flamed.
  2. Plymouth 65
    Plymouth 65 Floorable Deplorable
    1,106
    1016
    Jun 27, 2016
    Mich
    Local Time:
    8:43 AM
    Old School, I like it! 65'
  3. fishmens67
    fishmens67 Well-Known Member
    7,881
    5357
    Nov 10, 2012
    idaho
    Local Time:
    7:43 AM
    Should be a strong runner with the 4 spd. :thumbsup:
  4. yellow rose
    yellow rose Walking the crooked mile
    22,904
    18892
    Jun 19, 2015
    Living on the razors edge
    Local Time:
    5:43 AM
    I wouldn’t use that cam with a tunnel ram, but I like it for the single 4.
    Two 750’s would be perfect for a tunnel ram, and they would NOT be edelbrocks.
  5. ValiantKindOfGuy
    254
    53
    Aug 14, 2019
    Plympton Mass
    Local Time:
    8:43 AM
    Edelbrock carbs make me sick lol. I’m probably not gonna run the tunnel ram I just had it sitting around. I like intakes that stand up on the port lol. The air gap I also have laying around and will go with. It’s gonna be a daily so if I compromise on the build it will be in the single vs dual plane department.
  6. ValiantKindOfGuy
    254
    53
    Aug 14, 2019
    Plympton Mass
    Local Time:
    8:43 AM
    I’m also really hoping I have no piston to valve clearance problems. I don’t think I will but I can always cut a little more if needed.
  7. RustyRatRod
    RustyRatRod Bla de blizhibliz de blatde blizi bla bla FABO Gold Member
    61,610
    33561
    Jun 7, 2010
    Georgia
    Local Time:
    8:43 AM
    You say flat tops but those should have valve reliefs.
  8. ValiantKindOfGuy
    254
    53
    Aug 14, 2019
    Plympton Mass
    Local Time:
    8:43 AM
    Yes they do it was implied. I didn’t know I had to describe it like summit. Flat tops with two valve reliefs.
  9. yellow rose
    22,904
    18892
    Jun 19, 2015
    Local Time:
    5:43 AM
    What tunnel ram is it?
  10. RustyRatRod
    61,610
    33561
    Jun 7, 2010
    Georgia
    Local Time:
    8:43 AM
    I don't think that combo has a snowball's chance in hell of piston to valve clearance.
    • Agree Agree x 1
    • ValiantKindOfGuy
      254
      53
      Aug 14, 2019
      Plympton Mass
      Local Time:
      8:43 AM
      Weiand hi-ram
      • Thanks! Thanks! x 1
      • Shorty Medlock
        Shorty Medlock Roads Scholar
        77
        67
        May 9, 2020
        Wisconsin
        Local Time:
        7:43 AM
        Wow...$350.00 for a cam?
        That cam isn't far off of what my kid runs in his dirt modified. Should be OK.
      • ValiantKindOfGuy
        254
        53
        Aug 14, 2019
        Plympton Mass
        Local Time:
        8:43 AM
        What world do you live in exactly? Doesn’t know head gasket thickness or any general clearances of the top end. Did you look at the cam specs? Look at the valve events and get back to me. Why must you always bust my balls when I post.
      • ValiantKindOfGuy
        254
        53
        Aug 14, 2019
        Plympton Mass
        Local Time:
        8:43 AM
        Solid flat tappet and lifters. Don’t forget I’m averaging off the shelf and custom.
      • RustyRatRod
        61,610
        33561
        Jun 7, 2010
        Georgia
        Local Time:
        8:43 AM
        What? I'm not busting anybody's balls. I was giving you my opinion that I don't think you should be worried about piston to valve clearance. I have no idea WTF you're talking about "HERE".
        It's all good. I'll move on.
        • Like Like x 1
        • ValiantKindOfGuy
          254
          53
          Aug 14, 2019
          Plympton Mass
          Local Time:
          8:43 AM
          I didn’t read it incorrectly you wrote it incorrectly. Just a Misunderstanding but go back and read what you said. You said there is not a snowballs chance in hell to have piston to valve clearance.
        • RustyRatRod
          61,610
          33561
          Jun 7, 2010
          Georgia
          Local Time:
          8:43 AM
          That's right. I typed it right. No way you're gonna have piston to valve clearance. It was in no way shape form or fashion a smartass, demeaning or otherwise skewed response. I simply said IMO you don't have to worry about it.
        • ValiantKindOfGuy
          254
          53
          Aug 14, 2019
          Plympton Mass
          Local Time:
          8:43 AM
          Also you do tend to be a tad grumpy when I post. No hard feelings just messing with you don’t take everything so hard.
        • Shorty Medlock
          77
          67
          May 9, 2020
          Wisconsin
          Local Time:
          7:43 AM
          OK.... wondered about that. I bought two in the last 90 days. One was $255.00 (Jones custom) and one was $159.00 (Howards old grind but still available on request). Lifters $90.00-ish.
        • ValiantKindOfGuy
          254
          53
          Aug 14, 2019
          Plympton Mass
          Local Time:
          8:43 AM
          Damn I’m getting screwed lol. Sorry for the poor pricing I’ll change it.
          • Like Like x 1
          • RustyRatRod
            61,610
            33561
            Jun 7, 2010
            Georgia
            Local Time:
            8:43 AM
            Nothing I've said has been smartass or any other "what you think" it might be. You asked a question. My response was that IMO you don't have a snowball's chance in hell of that happening. Now, why do you think that's smartass, insulting or "whatever" is totally beyond me. Those valve reliefs are very generous. Even if the piston is .020" out of the hole.
          • RustyRatRod
            61,610
            33561
            Jun 7, 2010
            Georgia
            Local Time:
            8:43 AM
            No, not been grumpy here at all. Might I suggest you limit your opinion of my responses to THIS thread in the HERE AND NOW and not worry about the past?
          • ValiantKindOfGuy
            254
            53
            Aug 14, 2019
            Plympton Mass
            Local Time:
            8:43 AM
            You’re still on this? Well ask any member to read what you typed and ask them if they think that means you’ll have no problems. You phrased it poorly and I whined about it and now you continue the whining. Go take a nap and change your diaper as I have already done so.
          • fishmens67
            7,881
            5357
            Nov 10, 2012
            idaho
            Local Time:
            7:43 AM
            Quit poking the bear. Who cares how it came across, Rob told you what he meant.
            I believe you have a good combo in the making. Carry on
            • Agree Agree x 2
            • ValiantKindOfGuy
              254
              53
              Aug 14, 2019
              Plympton Mass
              Local Time:
              8:43 AM
              I know I know I’m just being a baby. Sorry Rusty. Hopefully it will be strong. I’m hoping for 110mph I’ll be happy with more though.
              • Like Like x 2
