I have a stock 340 325hp with low miles on it. Looking to go to a little more aggressive camshaft, but not anything that would require mods other than perhaps 1.6 rockers. Will be used primarily on the street with the occasional strip runs. Suggestions?
Or perhaps I have a life outside this message board.He has been asked these questions like 6 times and hasn’t bothered to answer them. Maybe he doesn’t understand them?
Actually I am doing a swap into a 2004 Dakota. Most likely going to stay with stock diameter tires which are 245/70R16, about 29.5 inches tall. Going to run a streetable gear, most likely a 3:55. I have an 8 3/4 posi rear with 3:91 gears in the Duster now. Not sure if the width will be correct for the Dakota and I certainly don't want the tires sticking out from under the fenders. May just put a chunk in the Dakota rear for now. Engine is bone stock with around 50,000 miles on it, and just purchased a complete 6 pack setup for it. The engine does have the high compression 2.02 - 1.60 heads. Don't want anything super radical, just something with a good lope that will be strong out of the hole. Can go with roller lifters and 1.6 rockers if profitable. Automatic transmission, not sure about any stall. Open to all suggestions, and thank you.What rear gears are you running ?
4 gear or auto ?
Guessing by saying 325 hp your saying you got the high cr & 2.02 340.
Stock specs are something like this
268/276 210/220 @50 429/444 lift 114 lsa.
Could go to popular 110 lsa add 0.040-0.050" + lift and 5 to 15 degrees @ .050" depends on what you are looking for, something like (or other brands with similar specs) comp cams xe262h or xe268h pretty popular upgrades.
Thank you very much! I will certainly check those out.I have a 69 Barracuda with a 340, 4 Speed and a 3.55 Sure Grip and headers. About 12 years ago, I added an Edelbrock Air Gap, 750 CFM carb and a Comp XE268 cam kit (cam, lifters springs). It is an awesome cam. It sounds great and has lots of power. I can melt the rear tires. This combo is good for 375 HP. If you want more power, look into the Comp XE272. It's a little more aggressive and will give you more power.
Thank you!What head castings do you have and what’s your compression? Manual transmission or automatic and rear gears? If automatic, what stall? Are you prepared to upgrade the valve springs? If going with a 1.6 adjustable roller rocker, I’d go with this cam and matching springs. Im fairly sure that this is the street force II that @junkyardhero mentioned. It’s on a 108 LSA, which is optimal for the 2.02 intake 340. The intake centerline is on a 104, but if you’re gearing is a little high and converter is a little tight then you could install it on a 100 ICL.
Howards, Hydraulic Flat Tappet Camshaft, Chrysler SB 273-360, 221/221 @ .050, .470/.470, 108 LS-Competition Products
Horsepower | ||||||
RPM | Phase 1 | Phase 2 | Phase 3 | Phase 4 | Phase 5 | Phase 6 |
3000 | 185.2 | 195.5 | 199.6 | 206.4 | 206.2 | 214.7 |
3200 | 195.4 | 206.1 | 213.9 | 220.7 | 220.8 | 229.3 |
3400 | 208.9 | 224.6 | 233.0 | 240.6 | 240.5 | 251.5 |
3600 | 224.8 | 238.7 | 252.7 | 260.8 | 259.9 | 275.7 |
3800 | 236.4 | 253.7 | 266.6 | 277.0 | 276.9 | 298.1 |
4000 | 249.5 | 267.6 | 280.0 | 291.8 | 291.8 | 311.7 |
4200 | 259.3 | 278.9 | 292.9 | 306.0 | 306.2 | 327.1 |
4400 | 265.0 | 287.1 | 304.3 | 321.3 | 321.3 | 344.6 |
4600 | 268.8 | 297.2 | 313.3 | 335.2 | 334.7 | 355.9 |
4800 | 274.7 | 306.8 | 321.1 | 343.1 | 342.5 | 366.7 |
5000 | 278.5 | 312.7 | 329.1 | 352.6 | 350.4 | 377.0 |
5100 | 280.2 | 316.9 | 330.6 | 354.5 | 352.4 | 381.3 |
5200 | 281.3 | 316.9 | 330.8 | 353.6 | 353.6 | 384.3 |
5400 | 273.7 | 314.9 | 329.3 | 350.8 | 355.4 | 386.1 |
5500 | 273.5 | 313.9 | 330.4 | 350.7 | 355.9 | 387.4 |
5600 | 269.3 | 314.5 | 330.2 | 350.9 | 353.5 | 389.4 |
5700 | 312.7 | 329.3 | 348.6 | 353.3 | 391.6 | |
5800 | 308.8 | 326.2 | 347.6 | 351.4 | 387.2 | |
6000 | 329.2 | 353.4 | 383.7 | |||
6200 | 314.8 | 373.7 |
Torque | ||||||
3000 | 324.2 | 342.3 | 349.5 | 361.4 | 361.0 | 375.8 |
3200 | 320.7 | 338.3 | 351.1 | 362.3 | 362.3 | 376.4 |
3400 | 322.7 | 347.0 | 359.9 | 371.6 | 371.5 | 388.4 |
3600 | 328.0 | 348.2 | 368.7 | 380.4 | 379.1 | 402.2 |
3800 | 326.8 | 350.7 | 368.4 | 382.9 | 382.7 | 412.0 |
4000 | 327.6 | 351.3 | 367.6 | 383.1 | 383.1 | 409.3 |
4200 | 324.3 | 348.8 | 366.3 | 382.7 | 382.9 | 409.0 |
4400 | 316.4 | 342.7 | 363.2 | 383.5 | 383.6 | 411.4 |
4600 | 306.9 | 339.3 | 357.7 | 382.7 | 382.1 | 406.3 |
4800 | 300.6 | 335.7 | 351.4 | 375.4 | 374.8 | 401.3 |
5000 | 292.6 | 328.5 | 345.7 | 370.4 | 368.1 | 396.0 |
5200 | 284.1 | 320.1 | 334.1 | 357.2 | 357.1 | 388.1 |
5400 | 266.2 | 306.3 | 320.3 | 341.2 | 345.6 | 375.5 |
5600 | 252.6 | 295.0 | 309.7 | 329.1 | 331.7 | 365.2 |
5800 | 279.6 | 295.4 | 314.8 | 318.2 | 350.6 | |
6000 | 288.1 | 309.3 | 335.8 | |||
6200 | 266.7 | 316.6 |
I linked to this same article earlier in this string. Pretty amazing results!Here's mild hop ups to a stock 340
https://www.motortrend.com/how-to/mopp-0102-1970-340-high-performance-mill-dyno/
Phase 1: Stock 340 baseline, Chrysler electronic ignitionPhase 2: Replace small production AVS with Edelbrock 800 CFM carbPhase 3: Replace factory HP manifolds with Hooker 151/48-inch headersPhase 4: Replace factory iron 340 HP intake with Edelbrock Performer RPM Air GapPhase 5: Replace SSI springs and retainers with Engle #604LS retainers and #993 springsPhase 6: Replace stock 340 HP cam with Comp Xtreme Energy 268
Show Less
Horsepower RPM Phase 1 Phase 2 Phase 3 Phase 4 Phase 5 Phase 6 3000 185.2 195.5 199.6 206.4 206.2 214.7 3200 195.4 206.1 213.9 220.7 220.8 229.3 3400 208.9 224.6 233.0 240.6 240.5 251.5 3600 224.8 238.7 252.7 260.8 259.9 275.7 3800 236.4 253.7 266.6 277.0 276.9 298.1 4000 249.5 267.6 280.0 291.8 291.8 311.7 4200 259.3 278.9 292.9 306.0 306.2 327.1 4400 265.0 287.1 304.3 321.3 321.3 344.6 4600 268.8 297.2 313.3 335.2 334.7 355.9 4800 274.7 306.8 321.1 343.1 342.5 366.7 5000 278.5 312.7 329.1 352.6 350.4 377.0 5100 280.2 316.9 330.6 354.5 352.4 381.3 5200 281.3 316.9 330.8 353.6 353.6 384.3 5400 273.7 314.9 329.3 350.8 355.4 386.1 5500 273.5 313.9 330.4 350.7 355.9 387.4 5600 269.3 314.5 330.2 350.9 353.5 389.4 5700 312.7 329.3 348.6 353.3 391.6 5800 308.8 326.2 347.6 351.4 387.2 6000 329.2 353.4 383.7 6200 314.8 373.7
Torque RPM Phase 1 Phase 2 Phase 3 Phase 4 Phase 5 Phase 6 3000 324.2 342.3 349.5 361.4 361.0 375.8 3200 320.7 338.3 351.1 362.3 362.3 376.4 3400 322.7 347.0 359.9 371.6 371.5 388.4 3600 328.0 348.2 368.7 380.4 379.1 402.2 3800 326.8 350.7 368.4 382.9 382.7 412.0 4000 327.6 351.3 367.6 383.1 383.1 409.3 4200 324.3 348.8 366.3 382.7 382.9 409.0 4400 316.4 342.7 363.2 383.5 383.6 411.4 4600 306.9 339.3 357.7 382.7 382.1 406.3 4800 300.6 335.7 351.4 375.4 374.8 401.3 5000 292.6 328.5 345.7 370.4 368.1 396.0 5200 284.1 320.1 334.1 357.2 357.1 388.1 5400 266.2 306.3 320.3 341.2 345.6 375.5 5600 252.6 295.0 309.7 329.1 331.7 365.2 5800 279.6 295.4 314.8 318.2 350.6 6000 288.1 309.3 335.8 6200 266.7 316.6
