green1
Idle it and spray carb cleaner around the intake-if it gains rpm, that's a leak. But no small leak will make it a dog.
Check: initial advance, total advance
Secondaries opening? can you feel them open/ if so, rebuild carb.
ports aren't mis-matched enough to dog.
fuel pressure at about 6?
no leaks in old lines? (pump would rather pull air, than gas; all the way to the tank.
what dist? 8 to 10 volts at run?
plug wires- run it at night and watch, or ohm them.
compression is?
kickdown correct?
I used to run them new, and still have 2; they don't dog, unless there is a simple problem.
compression is?
kickdown correct?
