I can't see where your personal hobbies have anything to do with this
See post #50. His dream engine is a blueprinted '71 340 with a '68 manual cam.I can't see where your personal hobbies have anything to do with this
And don’t forget a 360 car will never be as valuable as a 340 car with numbers matching engine or not. KimI wish I would have started a list years ago of the guys who have said “I don’t want to push my 340 to hard because it’s the original block”. So they stick with running 14’s or maybe stick a set of headers, intake, and carb change and run low 13’s. No wonder the GM guys make jokes about us. Lol
I doubt it. The dz302 is one of the Generals' all time classics as is the 327!
Not really. You just posted the vaguest question imaginable and left people guessing as to what you meant.Man I really did divide the small-block family LOL
You are talking to the wrong guy there. I couldn’t give a damn about value. Cars, guns, or whatever I buy them to beat on and use.
360 because when built dollar for dollar they are faster.
I don’t think the machine shop did the labour for free? Do u? KimExhibit A?
1968 340 rebuilt
U can ask whatever u want. Doesn’t mean u will get it. The price is a little high. U can buy a BluePrint 408 for that. So u have a choice to buy it or not. The 408 on Craigs List was a steel for whomever bought it. KimAbsolutely not. But that doesn't seem like a lot of money to you? I'm comparing that to a 408 that was for sale locally for $2500. Same deal: fresh build, never run. It sat on Craigslist for at least a month.
A 360 is just a stroked 340 with larger main bearings, but a 360 can be bought for a whole lot less money than a 340.
Comparing stock stroke to stock stroke, at one hp per cubic inch, the 360's twenty extra cubes will be worth 20 extra horsepower at the same compression ratio. Back in the seventies, eighties and into the nineties, there weren't any good, inexpensive zero deck pistons for a 360, which hurt 360's compared to 340's, but that's no longer a problem.
The 340's smaller main bearings might cause a bit less friction loss than the larger ones in a 360. But I would think a 4-inch stroker crank might be more rigid with the larger 360 mains than with 340 mains.
At any rate, they are pretty close to being the same motor. I am running one 340, plus have an standard bore spare 340 block. Also running one 360, with one spare 360 block. My 340 and 360 are equipped pretty much identically - cam, intake, heads and exhaust - except the 340 has maybe 1/2 to 3/4 point higher CR. I can't really tell any difference between the two in the seat of the pants, although that's complicated a bit by the 340 being a 4-speed and the 360 being an automatic.
For a concourse restoration of a factory 340 car, you kinda need a 340, although once in the car the two motors can hardly be told apart, especially if the 360 is internally balanced. For a modified motor, it makes more sense to start with a 360 just because it's so much cheaper than a 340, and originality doesn't matter anyway.
Just my two cents.
I cannot agree more.You are talking to the wrong guy there. I couldn’t give a damn about value. Cars, guns, or whatever I buy them to beat on and use.
Why? 350s came with steel cranks too.The 327 is a far better engine than the 350.
You can get a Blueprint 408 stroker cheaper with a 3 year, 50K mile warranty. Carburetor to oil pan.Absolutely not. But that doesn't seem like a lot of money to you? I'm comparing that to a 408 that was for sale locally for $2500. Same deal: fresh build, never run. It sat on Craigslist for at least a month.
