The picture clearly shows detonation damage to the piston.Any magnefied close ups of the plugs? I think YR is wants to see the deposits on the porcelain, if any.
If I didn't already have alloys, I might follow you.I'm close to that now, and a gasket change or advancing the cam a bit would put me there. And it won't rattle.
If you pull it down you should be able to cut the domes off the pistons to lower compression but that will probably affect the balance of the rotating assy. So will new flattop pistons.Don't have any close ups of the Plugs. Plugs are relatively new so may not be a great indicator of much. But it looks like most everyone agrees looks like detonation marks. If I correct the detonation is there any issues running the pistons as is? Clearly if I yank the motor I would replace the pistons. Was wondering if I could shim the heads to lower the compression which would be the easiest way but not sure if that would be enough to lower the count by 2 which maybe whats needed...... I have to find someone with a Whistler here in Phoenix.
Racer Brown Racer Brown Datsun 510 camshafts & valve timing datsport
Chapters 1,2,3 worth a read
Chapter 6
Chapter Seven DEFINITIONS Cam Selection
Chapter Eight OTHER ENGINE MODIFICATIONS Displacement angle is LCA
Chapter 9 PISTONS AFFECT BREATHING, ETC.
Chapter Eleven Valve Springs last paragraph
Valve Spring Detailing
Checking Installed Spring Height and Other Details
Chapter Twelve (end of) Checking Valve Timing and Valve-to-pistons Clearance
Chapter Thirteen How to Make Timing Corrections
cut domes down/ off lots of times without reballancing with street rpms
heavier is worse than lighter IMHO and those are not light pistons
depends on your heads if you should run thicker gaskets
ok with stock heads but I'd work on my combination if I had wedge heads
YR and I have different applications
No quench ok if you are reved up
If around town or towing then quench is esier to live with
cheeers
Shrinker wrote about this and it really got my attention. The discussions you guys have been having here have really helped get a better grasp on what he was talking about.I love the fact that RB explains why R/S ratio DOES make a difference, especially in induction limited applications. But IMO it makes a difference in how you select your timing events. A higher R/S ratio affects when the piston reaches max velocity and how it moves around not only BDC but TDC.
Shrinker wrote about this and it really got my attention. The discussions you guys have been having here have really helped get a better grasp on what he was talking about. View attachment 1715456607
Motorsports Village • View topic - Initial timing
That would be me.my link was broken some other good person posted the new link
Really like what you wrote. Only quibble was the deleted word.
I think of getting the correct amount of heat into the mixture during compression as very important.
Getting enough heat in at idle and tooling around town is a problem with low compression engines with lots of overlap. Not dealing with low comression here, but interesting to contrast the situations.
Yes you are right but that is specifically due to the drawbacks of a typical 4-stroke gas engine running on liquid fuel. Heat is needed to vaporize and mix the fuel and air before it's burned especially in carb'd engines. If it is possible to get the fuel completely vaporized and mixed with the air inside the cylinder without using any heat you will have a much more efficient and clean-burning engine. That's why I mentioned the HCCI, in theory it uses no spark plug and compared to conventional engines has a very cold combustion with rapid but controlled burn. Basically in one of those engines the mixture is compressed to where it auto-ignites but the ignition doesn't start at one "point" (spark plug, or injector tip in a diesel), the entire mixture lights off simultaneously.
As you can probably guess the main problem with its application right now is how to control it since there is no device to initiate the combustion process and we all know how tricky and persistent uncontrolled detonation can be when you're pushing the envelope... Really tough to not make things go BOOM
Yes. If it can be done. I've had hopes on technolgy before - such as stratified injection - that didn't/couldn't be implemented widely.
My takeaway for our stuff is that we need to get sufficient heat in at idle - especially when we've mucked up the vacuum which normally aids in partial vaporization and distribution.
Shrinker wrote alot about fuel conditions and reactions. He was always investigating, asking and learning - and sharing. I understand enough of what he wrote most of the time to get the gist. Sometimes I get a little more when I go back and read again...
here commenting on dyno testing of a 440
Motorsports Village • View topic - Dyno time
I've posted this one before
Motorsports Village • View topic - How a Wideband gets tricked to read wrong AFR
and way deep relationships of fuel, heat, pressure, products of combustion...
Motorsports Village • View topic - Timing/jetting Shrinker
One thing that I really have come to appreciate is that he tried to get us to see things from the combustion perspective, and then work back to what needs to be done. It's the totally the opposite of the way most of us got into this. We were advised 'change jets' or 'change timing' or 'add squish' etc etc. and see what happens. Shrinker says - try to understand what is happening in the cylinders and then make the changes that ought to correct the situation. I think that's what some of you guys who have worked with engine tuning alot do. But those of us who did not have to make a concious effort to think that way.
Should be all in by 3000 rpm max I would think.That's awful slow for my tastes.
What spark plug are you running?
Every engine is different.Should be all in by 3000 rpm max I would think.
Maybe play around with the Wallace calculator. Punch in all your variables and then play with the gasket thickness to see what you get.Guys’s Never calculated the stack up but was wondering how much compression loss could be achieved with either thick head gaskets or “shims”. Is it on the order of a point or tenths of points?
As a rule of thumb, you can count on approximately 0.1 point loss of compression ratio for every .005" increase in head gasket thickness for these engines, in the typical compression range we run. For a specific amount of thickness increase, the changes in CR will be a more on higher compression engines and a less on low compression enginesGuys’s Never calculated the stack up but was wondering how much compression loss could be achieved with either thick head gaskets or “shims”. Is it on the order of a point or tenths of points?
