Is it possible it has a solid lifter camshaft?
That's a good thought. Check the position of the rocker shafts. They are notched and go a certain way. Why does the timing change so much over the stock setting of 5 degrees btdc. When I listened to the video, it sounded like a exhaust manifold leak, but not sure. cool car!
