Rat Bastid
Dunamis Metron
Good! Looking forward to the build.
When are you starting it?
After I get the last one back together this spring. I have to see about pistons first. I’m expecting 20 weeks minimum.
No, you give me one "would've" and an 8hr youtube video.
With to so far.
Yes, 25% more power atrokes, with 25% less torque created from each one.
So same horsepower. Got it
Yes, but again, it's making less torque with each of those power strokes.
Which is why it needs more of them to make the same horsepower.
If you have two engines with equal horsepower, but different operating RPM, if you optimize the convertor, gear and chassis etc to use the horsepower where it's available in both.
They will both provide the same level of performance, or at least extremely similar.
That's entirely my point.
Not unless it made more horsepower.
Absolutely, this is a given.
Not if you're reducing the torque in equal proportion to the increase in RPM to arrive at the same horsepower.
Hmm, You do understand that optimising gear ratios can be done for lower RPM engines as well, right?
It's not a thing that only exists for high rpm engines, gear reduction is a scientific principle that can be applied wherever it's needed.
Like, there are 8sec diesel pickup trucks running on the street. And they do it with ungodly amounts of torque.
Try telling them "RPM is king"
They''ll laugh in your face.
Will be commenting on some of the other things later, at work here in Aussieland.
Here’s your chance!Nothing worse than a fool who can’t figure it out.
@Rat Bastid What was it you think I don’t understand?
Here’s your chance!
Let the schooling begin! How does the math work?
I depends on how much power you want to make.When saying a 340 needs rpm doesn’t have to be 8000 + rpm’s.
What are most people building 340/360 to 300-450 hp that’s like 4500-6000 rpm for a 360 and 4800-6400 for a 340 and even a 318 would be 5100-6800 rpm obviously those are generalized numbers.
LOL.LOL, decided to check in for a laugh.
You can’t imagine what I’ve done and what I’ve worked with.
Stop being a jealous baby.
Here’s your chance!
yes the cocky guy in his 1957 chevy 327 m22 456s 175 shot of spray my buddy was in his car he was shifting@8000 he was trapping 112@ the track8000 rpm is nothing to the small block Chevy guy's, kinda a normal thing for years.
Most of them ran a minimum 4.11 gear on the street, mostly 4.56 with a power glide.
There was a tunnel rammed 4sp Nova that spun 8500 during street duty. lol
Wow, that's quite a story!yes the cocky guy in his 1957 chevy 327 m22 456s 175 shot of spray my buddy was in his car he was shifting@8000 he was trapping 112@ the track
laughed at my 340 duster 243@50 507 108lsa 727 stock stall 3.23s 26.99 L-60-14 125 shot of spray my best trap was 108 mph
race 1 sucked him 4 cars outta the hole sprayed right off the hit never saw him but heard him he was at my back bumper he lost 1 car
pulled over talked he was humbled didnt think you car was that quick he said can we race again sureeeee
he went home advanced his timing ice in the cool can some race gas
race 2
i decide not to spray the hit wait till 3k in 1st broke loose when they spray hit he was at my back bumper he banged 2nd and jumped to just before my door banged 3rd jumped up to my side mirror missed 4th and he was gone he did not ask for a another race he coudnt get over that my car trapped in 2nd gear and he lost
8000 rpm bfd
He built engines in a race/marine shop had everything available to him
my whole car cost 800 he prolly had 3k in his engine alone it was a beautifull bronze color and it sounded sick i was supposed to lose
lol
At the end of the day we are all playing with the cheap 50 year old junk. Everyone on here crying that’s it’s 4 or 5 grand for a rebuild and a few parts. You start playing in the big boy sand box when a single head costs more than 10 grand before any finish machining…LOL.
The Trans and converter I have sitting in front of me is probably worth more than you've ever spent on an engine..
YepYou start playing in the big boy sand box when a single head costs more than 10 grand.
LOL.
You're going out of your way to ignore the fact that when it comes to fasteners, the whole is greater than the sum of it's parts.Come on dude. Now you just want to argue.
To compare that lift plate to eight rocker arms working on eight valve springs at 50 or 60 times a second is just stupid.
Set the engine on the ground and then jerk it straight up two feet and then stop it. Then slam it down as fast as you can until it barely touches the floor and see how long those little bolts hold up. It won’t be long.
Look at a 5 stud wheel vs a centrelock wheel.
When there's 5 fasteners, look how small they each can be.
When there's just 1 fastener look how large it's required to be.
The strength of the shaft rocker system isn't the size of the fasteners, or even specifically the quantity.
It's the fact that they're all fastening the same shaft together in unison and working together, rather than working individually.
Is this actually how you think valve springs work?
Do you think applying this kinda force would pull a 7/16 chevy rocker stud out first? Or a chrysler rocker shaft held in by five 3/8 bolts?
Something tells me I'm not going to get an answer to this obvious question.
Back on ignore.
LOL..Oh I’m sure it is. Assumption and arrogance is your forte.
Back on ignore you go. I have a new rule. Every wanker from down under goes on ignore from the jump.
Of course, if I trolled you like you troll me I’d be gone. It’s special there are different rules for the favored kiddies.
Buh-bye wanker.
Why put him on ignore at all? Looking at his response, replying and putting him back on ignore. Ya wanker. lolIll give you the answer. You’d know this if you had any experience in anything other than arguing.
Five 3/8 bolts will NOT hold the shafts down under load unless you run hydraulic cams or really small SFT stuff.
The five 5/16 bolts on passenger car heads will barely take a .600 net lift SFT. You can see the witness marks saddles.
I‘d post a video of what happens on a BBC chevy when the bolts can’t hold the rockers but it won’t help you understand ****.
I know exactly how a valve spring works and you inferring that picking up an engine with four 5/16 bolts is as much stress and strain on the fasteners a rocker shaft bolts shows your limited experience and foolish ignorance.
Back on ignore.
