Thanks for sharing ,what valves did you go with?Ok.....Here is what they got.......not great but not terrible...
I definitely don’t feel you can compare numbers from different benches as “apples to apples”.
That being said........ the intake numbers look pretty decent...... the exhaust is a little weak.
Is that with the supplied valve job, or after some tweaking?
What did those cost again?
Have they ever tested an ootb RPM head for a SB Mopar, where the numbers could used as a comparison?
now we all know what they did on one flow bench......
Tested on my bench in 8/17, an unported Speedmaster SB head, ootb, on a 4.00 bore was 261/[email protected] lift.
I think John Cadamore had one on his bench at some point as well.
What did the Promaxx head flow?
I can't find where/if you specified in that thread, was that with the stock MAXX 171 version or the Shocker 185 CNC version? The ProMAXX site says the 171 will do [email protected]" on the intake and the 185 CNC is at [email protected]". Your result on your bench was in the middle, [email protected]".
Maxx 171 SB Mopar (Sold in Pairs) - PROMAXX Performance Products
Shocker 185 Mopar CNC (Sold in Pairs) - PROMAXX Performance Products
damn, the promaxx heads are a deal.
What's the deal with the 63 and 65 cc chambers? Looks like the 65 is a little more of an open chamber design? That small difference in volume won't be much over 0.2 points of compression will it, even with the piston out of the hole a little?
Are you going to buy a set. or are you just a salesman.Mopar Chrysler SB 318 340 360 170cc 65cc Cast Bare Aluminum Cylinder Head 12933010742 | eBay
$357 each for bare castings
