Unconventional
They had quite a few different duties they did.What confuses people most is the fact that Ford used the big block bellhousing pattern on the 351M and 400, so people thought they were big blocks. They are not.
That iron head Ford 2300 in that ranger is like their version on the slant 6 they are pretty indestructable. 240K it may just live to over 300k as.long as you dont run it out of oil. If your waiting till it pops to drop in that 351C , you may be waiting awhile LOLUnfortunately the engine in there now is a 4 cyl. And the mustang is the 3.8, so neither would be a drop in fit. I got the ranger for basically free, and it gets driven daily with the current engine and 5 speed manual transmission. But has 240,000 miles on it, so eventually it is going to give up. I also have a 4 cylinder perkins diesel that I picked up for $100 that was out of an '84 ranger. That may go into a little rock crawler project. But that's another day.
Esslinger has the technology to make those 4 bangers run![]()
My son and I have talked about putting a turbo to the 4cyl in it. Or doing a healthy rebuild on it and bump it up a little bit power wise.As does Boport. The 2.3 is a very under rated engine. I am presently building a 2.3 turbo engine.
If I can find an '85 SVO Mustang I like, I'll be all over it. Just a lil 4 bangerMy son and I have talked about putting a turbo to the 4cyl in it. Or doing a healthy rebuild on it and bump it up a little bit power wise.
Look up Turbo Joe Morgan. He runs a 2.3 turbocoupe engine in a 71 pinto hatchback. Its an insane drag car.As does Boport. The 2.3 is a very under rated engine. I am presently building a 2.3 turbo engine.
you know what's interesting? I had a Cleveland, and some really good Ford guys couldn't decide if it was a big block or small block.... LOL. I've had some 302's, 289's, a Windsor, a Cleveland in small block Ford. My personal favorite was the 289 (even though the Cleveland had more power).
The 300 six was in my opinion one of the best engines that ford ever built. I had one in a 4x4 ford truck. Had a set of headers on it, looked like a plate of spaghetti noodles. But man did that thing make gobs of just stump pulling power. I had a big *** lift kit and 36" mudders on there, I would wheel that truck everywhere. I'd load it up with firewood down excavator logging trails and power through the mud with a chain hooked up to big ol chevy 4x4s pulling them out of axle deep stuck mud all the way to the paved road. I miss that truck. I search craigslist for it regularly. If I ever see it again for sale i'll buy it right away.Those really good Ford guys should know, if they're really good Ford guys, there's no such thing as big or small block in Ford.
FE's, Y-blocks, FT's, 335's, 385's, MEL's, Windsor's...
All engine families, not inhibited by cubic inch size.
For example, the FE ran from 332 all the way up to 428 with a 427 in between.
Edit: let me correct myself. They "did" have big and small blocks. In inline six cylinders. The 200 was a small block, the 240 and 300's were big blocks.
They were gas hogs though. I think my compnee work truck managed about 12mpg on the highway, certain the work truck gearing played a big part in that also.
Yeah mine never got good milage, but back then they still sold leaded gas and it was like .90 a gallon. And I worked at a gas station, lol. Man, I am really missing that truck now after thinking about it again. I have to find that thing. I sold it locally 20 years ago.They were gas hogs though. I think my compnee work truck managed about 12mpg on the highway, certain the work truck gearing played a big part in that also.
my '72 short bed 390 used to get 16mpg loaded, unloaded, flat ground, hills, it just didn't care. Roast the L70s for half a block![]()
