360/904 question 65 Valiant
Transmission and Drivetrain Tech
  1. Litz
    Litz Well-Known Member
    250
    18
    Aug 10, 2016
    Deer Park WA.
    Local Time:
    12:06 AM
    I'm in the process of swapping the 65 273/904 in my 65 Valiant for a 73 low mi. 360 that came with a 727. From what I've learned I would be better off with a 904 rather than using the 727. My question is what year 904 trans. should I be looking for to use with the 73 360? I don't want any balance issues. Thanks, Litz
  2. abodyjoe
    abodyjoe Well-Known Member
    21,906
    7871
    May 22, 2004
    Berlin,N.J. 08009
    Local Time:
    3:06 AM
    Balance problem isn't the trans. It will be the converter. A b&m flexplate will do the trick.
    Somewhere in the late 60's they changed the spline count on the 904. Look for a 70-up 904 and you'll be good to go
  3. 65 Dartman
    65 Dartman FABO Gold Member FABO Gold Member
    12,427
    3815
    Sep 24, 2006
    Strasburg, VA
    Local Time:
    3:06 AM
    Are you keeping the 65 904? If so use the B & M flexplate and the bushing that goes in the 360 crank pocket for the smaller snout in your 65 converter. If swapping out your 65 904, try to use a 68-up so you don't have to use the bushing
  4. Litz
    250
    18
    Aug 10, 2016
    Deer Park WA.
    Local Time:
    12:06 AM
    Thanks for the info. I wonder if anyone would be interested in my 65 cable shifted 904 complete with console?
  5. Litz
    250
    18
    Aug 10, 2016
    Deer Park WA.
    Local Time:
    12:06 AM
    No, going to a later 904.
  6. abodyjoe
    21,906
    7871
    May 22, 2004
    Berlin,N.J. 08009
    Local Time:
    3:06 AM
    i'm sure someone will be interested in it..
    • Agree Agree x 1
    • AJ/FormS
      AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s
      21,253
      8515
      Jan 19, 2014
      South-Central Manitoba,Canada, 900ftelevation
      Local Time:
      2:06 AM
      By 71 most of the desireable upgrades were done to the 904, so any 71 up is good. I think almost all the 904 TCs were low stalls tho, so depending on the cam in the 360, that might be a sticking point. Lo-stalls were around 1750 with 2bbl teeners.
      But since you already have a 904........
    • Locomotion
      Locomotion Well-Known Member
      3,216
      790
      May 31, 2004
      Florida
      Local Time:
      3:06 AM
      727_fig2.jpg Be careful about going to the much newer 904's. They started going to lock-up converters in the late '70's. Older converters don't interchange with those. They can be recognized by a smooth, machined tip on the shaft.
    • Locomotion
      3,216
      790
      May 31, 2004
      Florida
      Local Time:
      3:06 AM
      Nothing really wrong with lock-up set ups. But it's not performance oriented and converter options are very limited. Good thing is that they also started going to the 2.74 low gear sets. But I don't know if all lock-ups had them or how to tell unless you disassemble it & know what to look for.
    • B-onefan
      B-onefan Well-Known Member
      1,307
      92
      Oct 2, 2009
      Texas
      Local Time:
      2:06 AM
      I would be, but since you are in California, and I am in Texas.......
    • Litz
      250
      18
      Aug 10, 2016
      Deer Park WA.
      Local Time:
      12:06 AM
      How could I find out which year they switched to lock-up converters? I have a good 1973 727 but want to use a 904.
    • B-onefan
      1,307
      92
      Oct 2, 2009
      Texas
      Local Time:
      2:06 AM
      See the picture posted above.
