yellow rose
Overnight Sensation
Like this
Ok .250-.375 will be good.
Some pick ups are made to just barely touch the bottom of the pan. Yours isn't like that.
Like this
I think I remember that thread, at this point I'm not trying to not use the main studs since the caps were lined bored with them and the bearing clearances were taken with the current setup, not sure how much it would change but I'm running tighter tolerances so I don't want to mess with it too much.I ran into that a few months back with the same pickup and tube. I was using factory bolts though not studs. I tried welding a stud onto one of the bolts which was a no go, so I did what I should have from the start and called up kevko. He had the correct mopar bolt with a stud on the end for around $17. Might give them a call and they should have something for you cheap.
Heres with the nut installed, i dont have the top of the threads sticking out through the nut but then again im wondering how much load is there. I secured it with red loctite still debating whether i take the washer out from under the arp nut for a little more clearance. The threads on the stud are 1/2-20
View attachment 1715153074 View attachment 1715153075
I wouldn’t touch it. There’s no real load there except vibration and the loctite took care of that. You have enough thread engagement.
Got the oil pan pan on and tightened.
Then while tightening the first head on, one of the threads in the block decided to give way while doing the final torque to 100ft/lbs!! Whats the normal fix, heli coil?
Yep. Tape everything and if you have to, snug a head on to help you keep the drill perpendicular to the deck surface.
Also, what are you using for head bolts? It's hard to see in the picture, but it looks like your bolt may be a bit on the short side.
Using the hex arp head bolt kit pn 144-3602, how long of a heli-coil should i get 1"?
1 inch will be fine.
Back in the early 1990's some studs were coming with the threads too long. When installed they would bottom in the hole, leaving threads above the deck. Seen several of them snap at that thread. Spent a bunch of time shortening the threads and then spot facing the head because the O.A. length was too short.
I would double check how much actual thread engagement you have with those bolts. Looks like it may be pulling on the top threads. As for how long the engagement should be, you'll have to look at a stock bolt and make sure from under the head to the start of the threads is correct.
Looks like the arp bolts are actually shorter when you take into account the washer that comes with them.
Is the oil pan on for good? I run the same pan and it is a nice pan, but I have one complaint about it. The drain is isntalled outside the sump baffle area. So when changing the oil about 3/4 of a quart won’t drain or drains VERY SLOWLY! I just welded in a drain plug at the rear corner.
It's on permanently for now, that sucks that the drain plug could be located better. Guess I'll have to deal with it. My one complaint with the pan was that the all the bolt holes were off and I had to grind most of them bigger so I could get the pan located. Don't know if there jig was off when they built my particular pan but all my gaskets laid in perfectly so I don't think it's the original block bolt layout that's the problem.
Cold lash should be .002 tighter cold. I've never seen lash close up with heat.
The geometry look dang nice. That's why that B3 kit is worth it's weight in gold. That's what correct geometry should look like.
Edit: yes, you are doing it correct.
Can't wait to see this done and running
Got my pushrods measured, ordered, installed and the valve lash set. Got about .017 clearance per rocker pair. Went with a thicker walled pushrod due to supply issues with the recommended size. Smith bros is a great company to deal with.
View attachment 1715164309 View attachment 1715164310
