Max340
I'd go with the 360 heads, and cut a bit off the surface to keep the CR up. The Exhaust valve diameter can be made a bit larger than the stock 1.60" if the guy doing the work is good. There is a bit of extra meat on the exhaust valve, so .050" isn't too hard to come up with. Swapping to the 360 heads gets you the larger diameter without any worries.
Back cutting the valves means they take "cuts" on the stem side of the valve head that make the transition from stem to valve head smoothly, thus allowing better airflow into the cylinder.
Because the 360 heads have larger runners, porting on the intake side can be minimal. Knocking down the casting edges and radiusing the bowl area just behind the valve seat will do plenty. On the exhaust side, port matching to the header gaskets will get you a load of flow, just stay out of the water jacket. Currently I have a set of 360 heads on a 340, and the exhaust side is ported out to where its easy to see the back side of the exhaust valve. It would not be a stretch to get a pingpong ball jammed in there, if that gives an idea of the cross section of the port.
