gzig5
Nice to see some experimentation. I wouldn’t hesitate to convert the stock hydraulic roller lifters to solids, but I don’t know what I don’t know.
Snagged a super good deal on the rear disc brake kit--couldn't be happier with the price! J.Rob
The number of holes = 15 which is 15/5=3 so yes triple pattern. 12.19" diameter and can't share the price as it was a wholesale closeout for dealers only--but it was WAY under a grand CDN $$$. J.RobIs that a triple bolt pattern rotor? What size and ballpark price for the kit?
I got a Pirate Jack rear disc kit for $450, 8 3/4Is that a triple bolt pattern rotor? What size and ballpark price for the kit?
Flats are 90 degrees out
Bingo. J.Rob
I'm open to suggestions. J.RobVery interested to see what you come up with for a dog bone for those lifters.
AMAZING, just simply OUTSTANDING!!!I will have to machine some custom "dogbones" because as you can see "Houston, We have a problem" .
I was all excited too because I thought maybe this part would be easy. The oil band is in the right location, they're super light, they feel absolutely silky in the lifter bores and all I had to do was machine the OEM dogbone flats .015" per side--Easy peezy.... Nope. Can you guys spot the problem? It actually took me quite awhile before I realized it. J.Rob
Do you have a picture of that set up installed?View attachment 1716022913
Looking at the Jesel style of hold down, I’m not sure you can get there with a typical magnum dog bone.
It’s not a mistake, it’s how those lifters and hold downs are designed. The stock magnum dog bones and spider are lift limited and that’s how the aftermarket gets around it. I do not have an installed pic sorry.AMAZING, just simply OUTSTANDING!!!
If not INCREDIBLE!!!!
I hope someone if not a gaggle of them shove their heads up the next guys *** and breathe deeply. Someone should be fired.
I think you misunderstand Rumble--these lifters are designed for a Chevy. J.RobAMAZING, just simply OUTSTANDING!!!
I was just wondering since I haven’t seen that part before.It’s not a mistake, it’s how those lifters and hold downs are designed. The stock magnum dog bones and spider are lift limited and that’s how the aftermarket gets around it. I do not have an installed pic sorry.
I did. Thanks.I think you misunderstand Rumble--these lifters are designed for a Chevy. J.Rob
Very true, but you didn’t say that. You said gen 7 bbc.Unless you have a bushed Dart BIG M , which can be .903.
