Using a pushrod length checker, in my .060" over 360 with J heads that have been milled .008", I measured the pushrod length to be 7.480". That is with .030" preload on the new, non-pumped up Howard's hyraulic lifters, with lifters lubed and sitting on base circle.
Can I use the standard 7.500" pushrods safely and effectively?
I have read where some guys preload to .050" anyways to begin with. How much will the extra .020" effect geometry, if I use the 7.500" push rods?
Thanks!
Thanks!
