360 Short block, X heads, rebuilt 904 , Performance parts
dpmalibu
Hatboro,PA
Just parted out a 1973 Duster . That all of these parts came off of.
1) 1979 360 Shortblock w/ low miles approx. 40,000. Stock bottom end/ dish pistons. has brand new Mopar Performance Purple stick Hyd. flat tappet cam. .478 lift 238 dur @ .050. 110 lobe separation. The cam is broken in and just has run time no miles on it. Asking $675
2) X heads : Completely rebuilt and ported also.Comes with stock rocker arms. Heads only have some run time no miles. have receipts/ flow sheet. $1750
3) Rebuilt (stock) 904 trans. No miles on it. $675
4) TCI 11" Breakaway torque converter. Part # 141300 $325
5) Hooker headers (Competition) Part# 5901 . Heads have wrap on them. Brand new(just have some run time on them). $125
6) Edelbrock Performer 318/360 intake manifold. part #2176 Brand new . Just has some run time on it $195
7) MSD 6A digital ignition box part # MSD-6201. $140
8) MSD Pro Billet Distributor # 8534. w/ Blster 2 coil Brand new just has some run time $200
9) MSD Super conductor spark plug wires. Brand new just has some run time $50
10) Whole MSD set up package deal $385
11) Brand new 3" exhaust w/ Thrush 2 chamber mufflers w/ turn downs. Fits 1970-76 Duster, dart Sport Demon $475
13) AutoGage 5" Monster tach w/ recall $100
15) Sun tach tachometer (white face ) $30
16) RCI 12 gal fuel cell w/ aluminum straps measurements 17x17x11 $ 100
17) battery box $20
18) Power master mini starter part# PWM 9613 $125
19) Sun triple gauge (white face) Water temp, oil pressure, volts $25
20) New Holley 750 cfm vac. secondary carb w/ fuel line List # 80508-3 $225
21) Holley 650 dbl. pumper. needs rebuild List # 4777-4 $100 (sale pending)
22) brand new alternator w/ single groove V-belt pulley. Also has custom aluminum bracket $125
23) AED throttle bracket $40
24) 21" Lokar throttle cable $40
25) 8.25" rear (open diff) unknown gear ratio. Axles have 3" extended wheel studs $275
located in Hatboro,Pa
Which Lokar Throttle Cable? I'll take it if 904.
interested in Mopar perf. valve covers, shift light and electric fan. can you post pic's ? PM sent
fuel cell is a fat bottom. I will post flow numbers of heads tomorrow.
I will post pics of the 650 carb tomorrow
Sent you a pm on the MSD package deal, let me know when you can thanks, also sent you my email just in case I can't access the site while I am out, thanks, Steve
Hi,
Please send Me Spec's on Your Heads with Pic's of them top & Bottom Veiw's. Also Please send Me Pic's of Your Headers too. My Question is will the Headers fit My 67 Dart?
Thank You Modog1967
Hi Again,
Please send Me Pic's of Your MSD Distributor & Coil and Starter.I'm looking for a Package DEAL???
I'm Seriously Interested because I'm building My 67 as I speak!!!
I'd consider Head's & Rockers as Well !!!
Someone is ahead of you on the MSD Package. If I don't hear from him by tomorrow night around 8pmthen I will let you know. I will have pics of the heads tomorrow. The headers will fit your car . I looked them up on Summit Racing.
Can you send me pictures of the carb please? I can message you my phone number if you could text me the pictures.
THANKS!
pics of heads. still working on how to post the flow #'s.
Do you know if these headers will fit 66 Barracuda 360 engine, i,m in Virginia but do not mine drving out to pick up. Thanks
