1) 1979 360 Shortblock w/ low miles approx. 40,000. Stock bottom end/ dish pistons. has brand new Mopar Performance Purple stick Hyd. flat tappet cam. .478 lift 238 dur @ .050. 110 lobe separation. The cam is broken in and just has run time no miles on it. Asking $675
2) X heads : Completely rebuilt and ported also.Comes with stock rocker arms. Heads only have some run time no miles. have receipts/ flow sheet. $1600
3) Rebuilt (stock) 904 trans. No miles on it. $625
4) TCI 11" Breakaway
torque converter. Part # 141300 $300
5) Hooker headers (Competition) Part# 5901 . Headers have wrap on them. Brand new(just have some run time on them). $125
6) Edelbrock Performer 318/360
intake manifold. part #2176 Brand new . Just has some run time on it $175
7) Brand new 3" exhaust w/
Thrush 2 chamber mufflers w/ turn downs. Fits 1970-76 Duster, dart Sport Demon $475
8) Sun tach tachometer (white face ) $30
9) RCI 12 gal fuel cell w/ aluminum straps measurements 17x17x11(flat bottom) $ 100
10)
battery box $20
11) Power master mini starter part# PWM 9613 $100
12) Sun triple gauge (white face) Water temp, oil pressure, volts $25
13) New
Holley 750 cfm vac. secondary carb w/ fuel line List # 80508-3 $225
14) brand new alternator w/ single groove V-belt pulley. Also has custom March aluminum Alt. bracket Part # for bracket MCH-40051 $100
15) AED throttle bracket $40
16) 36"
Lokar throttle cable cut down to 21" for proper fit on A-body w/ small block Part # LOK-TC-1000U36 $30
17) 8.25" rear (open diff) unknown gear ratio. Axles have 3" extended wheel studs $250
18) stock replacement small block motor mounts $30 (like new)
19) Summit Racing Valve cover breathers $20pr.
20) Holley mech fuel pump slighty used Part # HLY-12-360-11 Max pressure 6.5-8 psi. Flow rate 110gph $20
located in Hatboro,Pa
