Wouldn't matter if bigger bore has more fiction, up side of displacement through bore size out ways negatives when building power. Why I don't get the 408 trend, i'd even rather build the lowly 383 over a 408.
You're an engineer?
Why don't you go build another 340 and show them how it's done.You guys think so hard I get a damn headache. Cut it out. Lol.
I know it's been a while since you tinkered with a 340 short block.
You spent 40 years getting the top end figured out, so I think it would be a great project for you to finish out.
The world's most powerful N/A 340.
I don't want to hear about money, I'm good at spending others.
While there maybe merit to the various ways of looking at this, the bottom line is cubic inch displacement rules the day. Then there’s that vs expense.Wouldn't matter if bigger bore has more fiction, up side of displacement through bore size out ways negatives when building power. Why I don't get the 408 trend, i'd even rather build the lowly 383 over a 408.
You’d think that right!You're an engineer?
Do you think the same side loading, but on a wider piston skirt creates more friction? Like, spreading the load over a wider area?Piston friction. With the larger bore, you have a wider thrust face on the piston, but it travels less distance
Sure about that ?The greater the contact area, the greater the friction.
I'm working on it, I'll get back to you.Since you guys are going over the edge let’s calculate these factors.
what effect does piston coating have. There’s gotta be a reason for it.
let’s calculate the difference between 10-30 oil, 10-40, 20-50, 40 weight, and 50.
How about lead free fuel, racing gas, E85, and alcohol.
spring, summer, and fall racing temps.
How about shift rpm’s. 5700, 6200, 6500, 6700, 7000, and 7500. Feel free to add any other rpm.
Don't feel intimidated, there's no risk that intellectuals are going to take over this forum..
Side bar,You guys are way to smart for me. I’m like “ Hello, is anybody out there”.
First of all what I'm talking about would fall into the "general" category..Going back to your post 89, maybe you missed the word 'generally'.
Post #92 is about as simple as it gets as an explanation.
