RAMM
The create engines have routinely dyno'd at 410+ every time. Do keep in mind that they have a 9.0-1 comp ratio and stock Magnum heads minus the springs to work with the cam. It is a really nice platform to go from.
Now think what the head could be with a capable porter and a slight milling. A few guys here were/are running them in Dusters to low 12's with the create engine OOTB and 11's when the car is put on a weight loose program.
Read the article Rumble http://www.forabodiesonly.com/mopar/showthread.php?t=257491
They detail what it took to get 409 HP with a Magnum 380 crate. Keep in mind they are also running a pretty good single plane, with a 750 Mighty Demon. Demons are great carbs on the dyno. That being said they are a great engine especially when yoiu consider the amount of production OEM parts used. J.Rob
