PRH
You didn't need THIS thread to know that J par is lost......
Well....... you got me there.
Don’t take this the wrong way...... but without good dyno data...... the P/S calculator is somewhat useless.
What is does is show you whats “possible”.
If your car sucks, the numbers are just that........ numbers.
If you don’t know how much power you have, and what the car weighs...... you don’t really know what it “should” go.
I’ve heard the “you don’t race dynos” thing for almost 30 years.
But I can tell you this........ if you don’t make enough power to run the number you want to....... you’re never going to get there.
On the other hand if you need to make 500hp to reach the target, and you make 550hp....... but the P/S calculator shows you’re making 450hp....... you don’t need to waste any money on the motor.
Work on the car.
Work on the car.
Post #55 I was just wondering if you had any major issues with the speed master heads.Honestly........ if he’s trying to learn something by comparing his high Cr stroker with a tunnel ram to an 8:1 360 with a std Performer on it...... he’s totally lost........ and going deeper and deeper into the woods.
The only similarities between the two motors are they’re both SB Mopars.
I thought you were making a point of how the J heads may have worked better on the motor you were building then the aluminum heads?
I think I saw some of jpars time slips and he was around 118 MPH (IIRC) and I guessed at 3200 pounds and I think that's where the 430 came from.
It appears the current combo has gone 112.
At 3400lbs the P/S calc “shows” 365hp for 112.... which illustrates my point.
It’s not likely that’s all it would make if it were on the engine dyno.
Take Jpars build.........
410” stroker with mild ported heads, solid cam and tunnel ram.
Compare that to my friends 406” Pontiac stocker...... stock compression, unported stock heads that flow 215, .420 let lift at the valve camshaft, stock intake with Q-jet.
Think about the difference you'd expect to see on the dyno if you ran them back to back.
Forget about what the actual numbers are...... just how much difference you’d expect to see.
My friends Firebird also runs in that 3400lb weight range.
Using the P/S calc....... the Pontiac “shows” it’s better by 165hp(15mph higher).
Now
3300 with me.
Front 1750
Back 1550
112 in the 1/4= shows 357hp
Before
3000 with me.
120 in the 1/4...= shows 397hp
From an approximate 600 lift 270 at 50 duration to around 500 lift with about 235 - 245 duration. Took off electric water pump and put on manual...
Now
3300 with me.
Front 1750
Back 1550
112 in the 1/4
Before
3000 with me.
120 in the 1/4...
I've broken parts at the start line. I'm very happy with my current configuration. After 10 passes at 2 tracks I'm within 4 tenths of my "goal et".One thing when using the P/S calcs is you need to apply some common sense and look at the overall combo and make the intuitive mental adjustments.
I’ve been talking to a guy who’s not super happy with his combo.
He had a motor done and was expecting it to be faster than it is.
Not only on the time slip, but from behind the wheel.
It was not dynoed.
We discussed what the combo was....... I told him it should be an easy 460-475hp build.
Then I had him tell me about the overall combo, and I told him what I thought it would run........ and that it would likely show about 100hp low.
He said I nailed it with the predicted ET, and I looked at the P/S calc and it showed 365hp.
He’s made a few tweaks, picked up a couple tenths....... no improvement in speed(so it still shows 365hp)...... which I’m pretty sure is a lifter/valve float issue.
Like I said previously, I like to use it as a yardstick of what’s “possible”.
Most decent street/strip and basic bracket combos should be able to run within 10% of what the engine dyno numbers indicate....... provided the car combo is pretty close, and you’re not racing at higher elevations.
Typical manual trans cars will usually be a little farther off in ET vs speed.
The 60’ times are slower than their auto trans counterparts most of the time.
So, for a 3500lb auto car...... say the motor dynos at 500hp.......90% of that is 450hp.
450hp@3500lbs shows [email protected].
This is if the car is set up pretty optimally...... correct gearing and stall, slicks, good fuel system, ign, etc.
For each thing that isn’t optimum, the performance will come down a tick.
If you’re not within the 10%........ it’s usually more effective to address issues with the “car” as opposed to the motor.
With manual trans cars, that’s often easier said than done....... or not really possible at all.
Any type of launch technique that doesn’t allow for full throttle balls to the wall type launches will just kill the ET.
With many street/strip cars...... that type of launch with slicks results in broken parts....... so often times the leave, and there for ET, is compromised in the name of reliability.
But this can really skew the numbers on the P/S calcs.
3300 with you in it? That's pretty good! I'm about 3200 lbs without me.Now
3300 with me.
Front 1750
Back 1550
112 in the 1/4
Before
3000 with me.
120 in the 1/4...
Well if you weigh a hundred pounds that makes us even...3300 with you in it? That's pretty good! I'm about 3200 lbs without me.
me 100? dream on....Well if you weigh a hundred pounds that makes us even...
318willrun was closest with the hp guess at 335hp.
I nailed the torque guess at 368ftlbs.
What did we win?!?!?!?!
