4 speed I.D. HELP!!
dan brooks
willoughby, Ohio
I picked up a four speed and would really like to know exactly what car this came out of. Here's the numbers that I have found on it.
side cover- C95664Z
3-27
Left side by bellhousing- 3-29-68
23 spline
right side of tailshaft- C-96707J
right side by filler plug- H-3
C97622
shifter mount is on rt front of tailshaft
Flat area on right side of trans- 8A267610
RP 8832446 0007
If you can figure this one out I'll put up the numbers for the aluminum case one I got as well!!
Thanks for all your help, Dan.
PP 833 2446 0007
New Process plant
833 4 speed tranny
2446 Tuesday March 19 1968
0007 7th tranny built that day,
mrmopartech
8=1968
A-Built at the lynch road plant
267610=167610 car built at that plant
Likely a B body with a 383
Find the vin that matches those last digits and you'll find the model.
