GMachineDartGT
Senior Member
Like many, I am almost finished with a manual trans swap. One thing that is overlooked is how many small parts there are to do the swap completely. For me, I was going from an original console auto 904 to a console 4 speed. My parts list was pretty long and expensive, even thought I started off buying a group of parts at a reasonable price. Just for giggles, I'll list my parts list:
AMD tunnel
Carpet
Console carpet
Clutch pedal set
Brake/Clutch pedal pads
Brake pedal bushings
Clutch pedal bushings
Clutch neutral switch
Reverse indicator light
Console
Lower boot
Upper Boot
Shifter handle
Shifter knob
Shifter knob lock nut
Shifter mechanism
Shifter mechanism mounting plate
Shifter rods
Shifter rod clips and washers
Transmission
Transmission fluid
Reverse light switch
Driveshaft (1350 joints)
Rear axle yoke
Clutch pedal rod
Clutch pedal rod and z bar washers and clips
Clutch fork rod
Z bar
Bellhousing ballstud
Bellhousing ballstud bolts (2)
Frame mount ball stud
Frame ball stud reinforcement bracket
Frame mount ball stud nut and lock washer
Ball studseals (2)
Clutch set
Clutch fork
Clutch fork boot
Clutch fork bracket
Clutch fork bracket bolts (2)
Flywheel
Flywheel bolts
Clutch bolts
Pilot bearing
Pretty good list, pretty sure its complete.
AMD tunnel
Carpet
Console carpet
Clutch pedal set
Console
Lower boot
Upper Boot
Shifter handle
Shifter knob
Shifter mechanism
Shifter rods
Transmission
Transmission fluid
Rear axle yoke
Clutch pedal rod
Clutch fork rod
Z bar
Ball studseals (2)
Clutch set
Clutch fork
Clutch fork boot
Clutch fork bracket
Flywheel
Flywheel bolts
Clutch bolts
Pilot bearing
