This crank pictures in post #65 @ the 6 second mark, is that the one that was used. Cut down from 2.375 to 2.200 sure, but that's no offset grind going on there. 6.700 rod, 1.485 compression distance and a stock stroke of 3.380 /2= 1.690 for a total of 9.870. 9.9980 stock deck height would yield a piston .110 below the surface, more likely than the factory being out of wack 100 thou. on their deck height. Just my observation, could be wrong. opinions may vary.
Cranks I've offset ground are verry obvious the journal has shifted.
