400 builds-anybody?? NON STROKER!
Very interested in the EFI results. Using isky ductile rockers and RPM heads.
Anybody built up a 400 that is not a 451 or bigger?
I have a set of Manley 6.965 long rods for sale over on Moparts that are perfect for a stock stroke 400. If you use the 6.965 long rods with common 1.32 high pistons you get a 0.005 deck height in a 400 block. That gives you good quench and a decent compression.
Andy, do you have a set of C body hi P.O. exhaust manifolds for sale? I need em to swap a 400 into the A body. Thanks
Wow! Talk about digging up an old thread! Holy grace robber Batman!
2010!
But I like it!!!!
I grabbed a 400 to build later. Stock stroke will be used. M1 single with a race TQ.
A friend of mine ran 383 crank 400s& he flew in a67 notch on the street.thats with 915s-292 cam.we wanted to build l 4the strip but no one give us permission,l guess it was because 451s are that awesome. I think it would take a couple trys to get the right cam/ cam timing
My non stroker 400 is at the shop right now, gonna be dynoed in about 2 weeks.
750 speed demon
rmp performer intake
stealth heads with adjustable roller rockers
Schneider cam 233 239 496 508
440 trw pistons yielding 10.1
stock bottom end from 76 400
Wish me luck.
750 speed demon
Wish me luck.
Which TRW pistons are you using? are the pistons near Zero deck?? I wanted to do something like that but only found cast pistops 1276 I beleive with 1.91 C.H
This motor was put together originally in 1996 using trw piston L2388f40. The idea is to open the 400 block .0020 and put in 440 pistons .0040 to raise the compression. They are listed on summit as discontinued but I don't know if there is a replacement.
BTW what does a Silvolite 1276 weigh as compared to a stock 400 "B" piston? Anyone ever weigh them?
I am going to say they are both very comparative in weight. The Silvolite catalog doesn't even list the weights of stock replacement type pistons.
Tom
A UEM 1276 piston w pin weighs about 1098g , the oem forged crank can handle a bob weight of 2695g's, A cast crank needs further modifications due to piston to counterweight interference, the forged crank is at its limit for being internally balanced, without adding heavy metal, this is a good 80 grams heavier than the stock piston. Why std? Used in a 70 over 383 for this build.
I was wondering the weights because a buddy wants to raise compression on a 400 and he was going to get a set of low compression 440 pistons and I remembered reading that the weight was off so I asked if anyone knew? You gave me an excellent explanation. Thanks, I'll tell him just buy KB240 or better make a 451 out of it
