Cracked is right about that. A good verter is a place money is well spent.
ok guys i picked up a 75 400 (thanks forest) and i plan to put it in my 70 duster to drive or may just end up selling the damn thing..but anyway had a few ??? for you guys..the motor is stock and i dont plan to spend alot of money on it as its just to drive..i however did pick up a tm6 intake for it and i have a 750dlb pumper carb... i spotted a cam (cheap) hydro CRANE CAM .504 .528 [email protected] and was thinking of picking it up and sticking it in the 400..i plan to go in the as it has some trash in the top of the carb.. if anything i hope to just put new intake gasket,timing cover,oil pan as i am going to see what things look like inside..oh i forgot i will be putting a set of 906 heads on it that has some port work done to them..low buck ride to just drive around and spin a tire...so i am thinking thin head gasket to bump the comp. if i came.. how do you guys think this low buck dont give a f--k motor will run??????the car has 4.56 gears and i have 28/10.5 tires and 27.5/10.5 tires qtp...so lets hear some input on how this thing will run or not run..what would you change??? no machine work unless it has to be done..but i dont see that being a problem..:joker::joker::joker::joker:[/quote]
That cam's one of my perennial favorites. It'sa 112cl and it works well in low compression (9-ish:1) engines - but - that 400's a stretch because it's only around 7.5:1. It will make good power but you'll have to rev it. It won't make it until about 4K.
I think it will run good if it's tuned right. In the Direct Connection Engine book under hydraulic cam testing they used a 3000lbs. Duster (without driver), 727 trans, 8 1/4 rear with 4.30 gears and 9" slicks. The 400 only had 8.5 compression with Stage IV heads. With a 509 cam it ran 11.82 @ 116.61mph! That's right from the Direct Connection Engine manual. Just my 2 cents. I'd go for it and let the tire smoke begin!
well being off work sucks so now i get to read some old mopar books..the 400 from 72 through 78 all came with 8.51 compression, and according to the mopar engines book if i cut the heads .060 the motor will be almost 10.0.1 rayer:rayer:rayer:rayer: at lease some things are looking up page 220 in the mopar engines book....:walk::walk::walk::walk::walk:
got the low buck 400 completely apart today .. all the bearing are in great shape no copper showing anywhere in any of them.. i checked the piston in the hole and i came up with 42th. in the hole..\\/ gonna get some rings and bearing and see what happen with the rest of the build...it has 452 heads on it now.. gonna put the 906 heads on it.. cam still in the air got some pics but got to go to work so im out til later gator :sunny::sunny::sunny::sunny:
............seeing that ur buying bearings anyhow i would just have the crank offset ground..........it solves the problem of low compression and relives the hassle of making things fit after milling the heads .060................kim.........
