txstang84
I'm not saying you're on your own, but I can't really say I've seen anything in the previous posts regarding the actual chamber volume in ccs, or the volume of what head gasket you want. If you post some solid numbers, CR is much easier to estimate. If I missed them somewhere in the text, I apologize...That being said, if you figure these numbers:
4.342" bore (stock)
3.375" stroke
.020" gasket
4.38" gasket bore diameter
.042" deck clearance
.25" to first ring
.004" bore clearance
85cc combustion chambers...
you get 9.1:1 CR...with 9:1, you can run more duration and not wreck your cylinder pressure and still have a good solid powerband. Now, granted I'm used to building small blocks < 3.5" stroke, and I'll probably need a flame suit here, but I was always under the impression when you start going above 225* @ 050" or 270-275* total duration with less than about 9.5:1, you lose a lot of cylinder pressure which translates to an engine that really doesn't wake up until nearly 3,000...a stall will help mitigate this issue, but it really won't be running up to potential if you bleed off all your cylinder pressure on the low end. So, cam choice is-as always-of paramount importance to find one that meets your expectation (within reason). I think there was someone on here that mentioned one of the Lunati Voodoo grinds-I'm on board with that suggestion...or the COMP XE cams...they make the most of the duration and lift profiles without tearing up lifters or lobes and they're not terribly expensive. I'd venture something around the 272-278 total duration would run great, sound good, and wouldn't need a huge stall or tons of rear gear to be a super fun daily driver.
Then again, my opinion is just like many others...it plus $1.59 will get you a cup of coffee at 7-11
4.342" bore (stock)
3.375" stroke
.020" gasket
.25" to first ring
