Pretty sure that Lunati cam is a billet steel core with a cast on ductile iron intermediate gear. Very sweet looking build, BTW!
They said their cast iron roller cam can take 500 open pressure? As long as they knew you weren't talking about a billet core, sweet.
Just an echo.. as far as I know ..it's the constant extreme seat load that can hurt a cast iron roller cam and not really so much the open of your average load requirement. Rock on!
I don't use beehives on anything.Would a beehive spring help alleviate this problem?
And if they were where it was at and top of the advancement scale... they would **** can the rest of the springs and everybody would be using them.Beehive/conical springs require less seat pressure & less pressure over the nose of the lobe. Less strain on the valve train. Used on many modern engines.
So is there a generally accepted conversion factor for beehive rating vs standard dual coil spring rating? How does one select the proper beehive if the standard spring requirement is all that is known?Beehive/conical springs require less seat pressure & less pressure over the nose of the lobe. Less strain on the valve train. Used on many modern engines.
Bewy, you're full of **** and the more you post...the more an asswipe you come off as.MO,
They ARE at the top of the advancement scale, maybe just not yours.
Trick Flow is a business - they are here to make money just like any other business. They ship their heads with "regular" springs because they will do the job and are cheaper. I would be willing to bet they would ship them with behives if they could get them for the same price as a conventional spring.Every new trick flow has what on them....hint, it's not a beehive , asswipe.
They are a premium head, not a budget head. They would be using elgin valves and pioneer springs if so.. nut they're using re boxed pac springs as far as I know and better valves.Trick Flow is a business - they are here to make money just like any other business. They ship their heads with "regular" springs because they will do the job and are cheaper. I would be willing to bet they would ship them with behives if they could get them for the same price as a conventional spring.
Then you didn't read or comprehend my reply...and my response was to bewy ,not you, so why are YOU perturbed and trying to manifest an articulated info packed response to yourself out of it? Aside from exotic race stuff in the 3000 plus range just to make it run..the trick flows are high end $2000 plus heads ootb, so really... tell me more how they chose the spring based on cost and not what a good fit and function spring would be.^^ I never said trick flows were a budget head.
Yes they use PAC springs (PAC also make quite a few different behive springs) I was saying if they could increase their profit by using a conventional spring that would fit the intended use over a behive or conical spring they would.
I have yet to see a broken behive spring myself but I don't have a lot to do with racing circles - I'm lucky to get to a track 2-3 times a year but I know plenty of people running them in street cars for years without issues.
Your post above would have fit this thread a lot better and promoted more relevant discussion than just stating "trick flows don't ship with behives asswipe".
It all comes down to personal preference - some people prefer fast rate cams, some people prefer edelbrock carbs over holleys & some people think a geometry correction kit is a waste of money.
Run what you want to run & let the next guy run what he wants to run without shitting on him
Heres what being missed....and it shows some have biased or predetermined options 'mind set'...
Someone said beehives are the best, top of the food chain...wheres the proof of that statement?
They have been around for decades....why arent they in everything? I can go look at 2000's year mopar muscle mags and see them....yet...about maybe what 15 % of us use them, and that might be a generous guess.
So where is this coming from besides an asswipe looking down from his mountain top..
I don't know you, but you call someone an "asswipe" and yet post this up ^.Just an echo.. as far as I know ..it's the constant extreme seat load that can hurt a cast iron roller cam and not really so much the open of your average load requirement. Rock on!
