408 Stroker Short Block Details: Blueprint Engines
Looking at the wrong side sir, his I'm thinking is the 8.05. That is a solid mid 12 sec van, love it!!
I was! You are correct!!!! 85mph.lol jesus!!! 12's in a chest freezer lol. That blueprint shortblock is a tank ;)
Man, I didn't realize them vans where so small. Keep bringing them 60's down and that monster will fly, you'll need to get you'r pilots license, way to go 12many.
Jeff
4th run a throwaway, was staged after burnout and next lane didn't know how to stage so tires cooled, nighttime and was cooler out also .....then spun and hit rev limiter. Oh well, 8.01@85.2 is the best 1st time out without messing with anything, just trying different launches. Let "even more" fun begin. Hopefully get some video up real soon
I think I know who I'm gonna call next time I need to haul something...youll be done in no time
One comment last night from an onlooker was about it being a service van on a call and replying "I'll be there in a minute"!! :)
Ok, mind is running nonstop about things to try and finesse, timing, carb, and launching the thing. One thing I'm kicking around, along with tackling the basics (first) is that I haven't done the plenum divider mod to the Weiand Action+ Intake. Read alot on it, what's a general range of increase as it would apply to the times I ran in the 1/8. I'm thinking I should have done it to begin with.
i feel like an open spacer is a quicker test to any science you're applying there...unless i'm thinking of something different when you mention "divider mod"
I could do that, but no clearance with the doghouse lid closed, I could test with it open to see, then do mod.
easier than removing intake, trashing gaskets, and then grinding... if an open spacer doesn't yield anything...which in the 1/8th, it may not... i'd leave it.
you don't have 1/2 inch of clearance?
About a 1/4" with the Demon air cleaner.
i know where you can get a flat base, and save some grinding..lol
14
It's their one that clears the choke on the street demon carb.
Yup.....been there....
I had a Stingray that I really struggled with to find the right drop base air cleaner that cleared my linkage AND still close the hood.....
Your van hauls azz....awesome sleeper!
Jeff
