I am in the same boat as you. I see little or no RPM drop when LU kicks on.
Cley
Cley
Yeah but we call the clutch that generates forward motion, the forward clutch, every body I know does it; and we don't care that Mopar called it something else. They started this mess.What is called the "forward" clutch isn't the front most one as mounted in the trans, that would be the high,/reverse. The "forward" clutch which is engaged in all forward driving gears is actually the rearward mounted one in position within the case. There are 2 clutch packs in that overdrive unit, I believe one is engaged all the time you're moving forward as well. I know that if one of the clutch paying the OD is bad you won't have reverse.
Good to know. I saw a Youtube video of a Jeep suggesting lockup was like a 5th gear. Perhaps it is if you have excess slip in the TC.It's just a lock up of the converter - don't expect more than 1-200 rpm drop. The OD should be the big drop.
I set mine up to actuate OD and LU manually with a coupe buttons and I love it! I just hit about 8000 miles on my 42 RH with a fresh rebuilt unit...
