racerhog
RacerHog likes his Mopars
Well?????
Thats a deeeeeeep Subject Mike....lol
Well?????
My guess is 550 hp and a whole lot of tq.
nope530-550hp and 570-590tq
nopeAbout 490-500 HP and probably around 550 lb/ft with the 950 HP
nopeIf there is nothing done to the heads an are "stock" as you say, Im guessing 485-500HP 520-530TQ.
Big gains with ported heads big carb. I built a 416 a few years ago with that cam/head and SV intake 950 carb, it made 575hp 550tq.
I had it warm and tested the compression and got 150 psi - I thought it would be higher but will re-check with another gauge to be sure its accurate.What cylinder pressure do you expect with this combo? I am running the XR286R as well and it runs very strong.
Also, thank you for the fantastic thread!
nopeStock heads? When do the Shay Dell ones go on? With stock RPMs I'm going to say 480/520
lol...
any more?
made over 500 ft-lbs from 3000 ( start of pull ) to 5300
So 500 lbs-ft at 5300 is about 500 hp. Hope you turned it up after that and hit my #.......
