Part of what used to make the 2355's so heavy is the 250 gram pin ? Not sure if they are still using that Pin ? ....but we used to order the 1915 SP Pin and shave 40 grams off right away(not sure if that's available anymore either ?)
Nothing wrong with the 2355, virtually indestructible, was/still is the default Slug for many.
Nowadays, given we like a lighter Piston for cheaper Balancing...
for the stock Rods sub-550 HP, we just default to the 9953 ICON for an inexpensive lightweight Forged Slug, that uses equally inexpensive 5/64" Rings.
Pin-Fit the Pins @ .001" in the Piston... run the Rods at Thermally installed "interference".... NEVER had a problem, and we have lots out there approaching 50K miles.
Christ, we have 15 year Old "Super Gas" Drag Engines out there running LY Rods with pressed Pins... still going strong.
NOT recommending it nowadays obviously, with aftermarket Bushed stuff available... just sayin....
