We will never know what it was. I'll post some pics to show it was way too hard.
I'm still very curious as to how many ft-lbs of torque it takes to turn the engine over (no spark plugs) without the valve train and how much with the valve train lashed to spec.
And what exactly does this mean?;and oil was shooting up in the head thru the oil hole.I primed it before first fire, oil pressure was 75 when it was cold and about 40 when warm. It's getting oil all the way up in the heads for sure. Vacuum leak somewhere is possible, all new gaskets everywhere in the motor. Rockers were covered in oil and when I pulled them off primed it again
What exactly does this mean?; and oil was shooting up in the head thru the oil hole.;I primed it before first fire, oil pressure was 75 when it was cold and about 40 when warm. It's getting oil all the way up in the heads for sure. Vacuum leak somewhere is possible, all new gaskets everywhere in the motor. Rockers were covered in oil and when I pulled them off primed it again and oil was shooting up in the head thru the oil hole.
