1969Fish
3/8" push rod. Any suggestions on drill bit size and process?
Yes it's a 3104 comp timing gear set. The crank gear is in slot marked A. When 6 is firing the A on crank gear is at 12 o'clock and the dot on cam gear is at 6 o'clock.
Correct. The cam gear dot is at 12 o'clock and the crank gear A is at 12 oclock. With it setting like that #1 is firing.
There is an A where the crank key goes. Then counter clockwise a few teeth is the A you line up with the dot on the cam gear.
Well...I think I have found the gremlin, after decking the block 20 thou and going to a 1.6 rocker a few the pushrods were hitting..one was the intake..I figure that it was holding it open causing it to push exhaust back up the intake. So shall I order a thick walled 5/16 or pull heads and drill the holes out and stick with the 3/8? I am still not sure exactly how the process of drilling them out will work..
Toally agree, also incorrect ign timing could have it popping through carb.Also too lean (maybe open leanout valve).No, I think that can't be it.The pushrod is most likely rubbing at 60% lift or more.
The valve couldn't have hung open or it would have spit out the pushrod, as the lifter crested the lobe and started back down. So it's it's just rubbing.
For your scenario to work,it would have to be at or near split overlap, when the intake is opening and the exhaust is closing, and by that time IMO the rubbing on an exhaust,would long have been finished, and rubbing on an intake would not yet have started.
But that got me thinking. I remembered that you said it didn't run very good and was popping through the carb, in addition to the overheat. Well it could very well be, exhaust backing up into the intake. But it would have to be for a different reason. Only three things I can think of; incorrect valve timing, incorrect valve lash, or a plugged exhaust.
-Earlier I think I said split overlap is easy to check with the intake off, and the timing cover/balancer still on.Just pick cylinder 1 or 6 whichever is easiest to reach. Put that cylinder at TDC Exhaust, which is actually split overlap. Put a short straightedge across the lifters. Reposition the crank until the lifters even up,and the straightedge lays flat across them. Then read the timing mark. On a single pattern cam the timing will almost always fall within a few degrees of TDC. On a split pattern cam it might be a little further off, but I imagine no more than about 8*. I use this as a shortcut, when I suspect a problem with cam timing. If I can't find the mark where I expect it to be; off comes the T-cover and out comes the degree wheel.I also use it after the cam is degreed in to see where it fell in, to verify I didn't screw up the cam install.
-As to the valve lash, what I really mean is that the intakes are not closing fully or are leaking.An LD test will prove it eitherway. If the exhausts don't spend enough time on the seats, they will get goodNhot. With alcohol, I doubt this would be a concern,especially at the rpms you were likely operating at.
-And a plugged exhaust is probably not on the table either.I just mentioned that for guys with dirtbikes that might someday stumble across this thread...
Eddy heads need the pushrod holes drilled/filled larger when used with 1.6 rockers.
Been there myself too with 3/8" pushrods.
I'm still very curious as to how many ft-lbs of torque it takes to turn the engine over (no spark plugs) without the valve train and how much with the valve train lashed to spec.
