1969Fish
So if it's too fat on alcohol it will actually cause it to get hot? What do you mean by washing out the cylinders?
Enjoying all the input.
.0065 x bore size for ring gap??
We are gonna check spring pressures again and take the inner spring out and put it back together with just the outer ring to see if it still binds, of course it will not be ran like that just a test.
Gonna pressure test the heads, and also try a set of 1.5 and a different set of 1.6 rockers we got laying around. Still don't explain heat problems. Maybe timing was waaay out causing heat issues???
Start with what came in the carb. I cant stress enough about low fuel pressure at idle 3-4 lbs at most .
most run a bybass system that gives 3 lbs at idle and 7 at wot.The steel needles and seats cant hold much more at idle.We have been sucessful on a manual fp at 5 with .130 ns.You cant tell by looking at plugs if your 10 sizes too big or small they will look new.If you have just an elec pump w/ reg turn it down to break in cam.Also be careful of your oil, it can milk up real quick and lose its lubricating quality.Talk to your carb guy and ask about n/s assys. that can hold more pressure.
ThisSounds to me like you are coil binding the valve springs. To much lift for the valve travel.
