flathead31coupe
Thanks I hope so... i looked there did not see anything
I was just going to post about the Mancini kit, a friend of mine bought one for his leaking 440 that he just rebuilt...so i just received my new mancini rear seal retainer kit no instructions....where do i get them?
Yeah I'm not sure if it's throw and go deal or if you actually have special procedures to use on that particular product I just know it's a fix-it for that problem area, unfortunately I've never used one myself so I can't help you however they're open in the morning I just give them a phone call about 9:00 or 10:00!I was just hoping it came with instructions lol
No Problem! They're pretty good about stuff over there. I've called and talked to them people more than once, I mean they get pretty busy, but they will spend a few minutes with you, to get you straightened out Perhaps they can email you something, or they could just give you some verbal instructions real quick...Thanks
That sounds like a Proper Procedure!If me, put the alignment pins in, prep the seals with a tad of silicon behind, roll in the block side if needed With light oil on the crank side. Make sure the lip on the half rounds is facing inward, put a light coat of silicon over the 4 side rings and lightly push it home. Pop out the pins and insert the bolts and torque to factory specs.
