flathead31coupe
How many have installed the Mancini retainer kit with the four little o-rings? And how did it work.
That's how I have done every single big block and slant 6 I have ever built. I never use the side seals for the rear seal retainer. I use RTV and never had one leak.The engine I just took out I put together years ago. No leaks dries a bone. The only thing I can see is it's a stock retainer with black RTV lol I just don't remember what I did.
Nope. That's aftermarket parts for ya. lol
Whoever talked you into getting that worthless bit of bling from Mancini, needs a boot up the ***. I'll say it, it's a piece of junk, yet Mancini keeps selling them, because Mancini suck.
You will send it back, and they'll just sell it to someone else.I appreciate all the input from everyone. The 440 I took out was dry as a bone and it was in there for I don't know how many years and I did that the way that I just done the last one. But I got sucked up to the latest greatest foolproof things. And it may work for somebody. But as you can see it did hit my main cap and wouldn't let it seat flush. I was just under the impression that it was clearanced and had all of the issues removed from it and it would be a great replacement. Live and learn lol
Good idea but I think you need oil pressure and the crank spinning to show it it truly leaks.
Here is what I do to check to see if everything is good.
Install the crank, lower seal and main bearings and torque everything down. Put white grease where the seal rides and turn the crank. I’m looking for a pattern that is 1/16” wide. Then I pull the crank and seal out and just put the seal in the retainer and repeat. If it is also 1/16” wide AND the upper and lower seal make contact in the SAME place on the crank you sould be good. One more thing, apply a small bead of “The right stuff” on the back side of the seals and on the seal ends where they contact each other. I also offset the seals in there saddle to make sure that there lined up as well. This is what works for me. Hope this helps.
I had real issues w/ my stock 440/505 seal, ended up finding the rear seal cap was machined off center on the \bolt holes , was off center when bolted down , none of the above would fix it !
I've noticed that most of the seal retainers are not centered, this is the entire issue IMO.
By using alignment pins and dropping the cap over an offset seal everything automatically lines up. The gaps between the block and the seal retainer are usually greater on one side over the other. If you try to center the retainer in the block with the seal ends flush the alignment can easily be off enough to leak.
I finally installed the cap/seal (under the car)and watched it pull side ways when it contacted the crank , go ta new cap from >I dont remember , maybe you know him !---LOL
