My pictures left with my ex wife's PC but I've built several Source part kits. The pistons are decent. The rods are acceptable to some however I will always have them re-sized and pin honed. The cranks are good value. I have not had to have one turned to correct it but they have taper on them on most journals that is close to or at the factory limit, the sizes are not uniform and lean towards the larger side so clearances are a little tighter on some journals. Otherwise, good value. IMO, if you simply accept what they tell you about it being in balance and ready to assemble, you really shouldnt be assembling one. They have issues that at minimum you should know about via measuring (something more accurate than plastigage). I have no trouble using their cranks, rods, and pistons. Valve covers, water pump housings, and any electrical I wont use.
