robert graves
New Member
46RH to 46re case can it be used ?
I bought la 1994 46RH for a project and after tear down I’ve discovered the case is cracked around the rear spray area, need a replacementThe short answer is no. What are you trying to accomplish? Use an RE case with RH internals and valve body, etc? If so, the answer remains no.
Sprag areaI bought la 1994 46RH for a project and after tear down I’ve discovered the case is cracked around the rear spray area, need a replacement
Do you have pictures of where it's cracked? If for some reason the sprag rolled (it's not common but still possible with enough abuse) and the outer sprag race damaged the case, then a bolt in sprag may be an option.I bought la 1994 46RH for a project and after tear down I’ve discovered the case is cracked around the rear spray area, need a replacement
Diesel/V10 case, either RE or RH will not bolt to a small block Chrysler.I see, has anyone got one to sell I can use 1994 46RH case , also is the earlier model 46rh case from the diesel different from the 5.2 gas ones ?
Need to put an ad in the parts wanted area. No doubt someone will have one for you.I see, has anyone got one to sell I can use 1994 46RH case , also is the earlier model 46rh case from the diesel different from the 5.2 gas ones ?
