3100lbs..?..
I think just about anything can be driven on the street...He drives it on the street too ? Awesome!
LMAO. Sorry to sidetrack. Not a street car. Trans brake, race glide and a 9" with a 4.88 if I remember correctly.I think just about anything can be driven on the street...
....LMAO. Sorry to sidetrack. Not a street car. Trans brake, race glide and a 9" with a 4.88 if I remember correctly.
3100# with 400 hp will get you to 11.53 @ 117 mph. 400 horse is fairly streetable and easy to get to.What does a 318 "on the street, all throttle, pump gas" have to run in a estimate 3100 A-body in the 1/4 mile before you say "That's a Killer 318" !!
....3100# with 400 hp will get you to 11.53 @ 117 mph. 400 horse is fairly streetable and easy to get to.
Your ET / MPH computed from your vehicle weight of 3100 pounds and HP of 400 is 11.53 seconds and MPH of 117.24 MPH.
Here ya go. Play a little. http://www.wallaceracing.com/et-hp-mph.phpI like it.....
I think 94 octane is generally considered top of the “pump gas” world.Depends on what you consider to be pump gas. Some can pump e85, but around here we have 110 on taps at 3 local Shell stations.
Our "high test" around here is 92-93 octane, but my point is I hear pump gas thrown around so much that it could mean anything.I think 94 octane is generally considered top of the “pump gas” world.
....Our "high test" around here is 92-93 octane, but my point is I hear pump gas thrown around so much that it could mean anything.
If you can drive it across 3 states and run pump gas and go race it, it's probably not all that wild of a combo. My 318 has compression close to 11:1 and iron heads, so it's not going to be super happy on 93/94 octane at a race scenario. I keep 110 in it due to this reason, but also because it can be had out of the pump and keeps great, so technically it's a "pump gas" engine. I'm not advertising it as such, I'll tell everybody and their brother it's 110 octane. Could I drive it across 3 states on pump gas? Maybe, but I'll probably never find out for sure.You could drive it across 3 states and pull into any gas station along the way, like Casey's, and not worry.
.....If you can drive it across 3 states and run pump gas and go race it, it's probably not all that wild of a combo. My 318 has compression close to 11:1 and iron heads, so it's not going to be super happy on 93/94 octane at a race scenario. I keep 110 in it due to this reason, but also because it can be had out of the pump and keeps great, so technically it's a "pump gas" engine. I'm not advertising it as such, I'll tell everybody and their brother it's 110 octane. Could I drive it across 3 states on pump gas? Maybe, but I'll probably never find out for sure.
The 110 I purchase comes from the gas station. We have 3 local stations that sell it. I just hear it so much that it can't be just a generic term, there needs to be a qualifier with it, like 93 pump etc.well, honestly, 112 octane that they sell at the track comes from a "pump", so one could say pump gas. But most folks generally consider pump gas "any gas station along the way" is good enough gas without detuning the car. My thought if a person has to "Question" if a car runs off of pump gas, then it doesn't.
I agree that is a killer 318. I think that there a quite a few killer 318s. In my book, if it genuinely shocks a person that it's "just a 318" then it's close to a killer 318.A guy on this site runs 11.7's with a 318 in a true street car on street tires and pump gas. That, in my book, definitely qualifies as a killer 318
