Thank you! I knew I seen/read this before.
I’ve haven’t heard anything bad about IMM so I just went with them assuming they were ready to run out of the box.I have always been sceptical of those being a true drop in deal. Especially for what they cost with the "required" pins.
Thanks, I’m dying to get this engine assembled so I can move on lol. That’s the exact flywheel I ordered on Tuesday and is supposed to arrive tomorrow. Then I can drop it off with the harmonic balancer in the afternoon and just maybe they’ll get the rotating assembly balanced early next week. I’m crossing my fingers!Hey man nice build! I use the American Powertrain 130t flywheel and a 10.5 clutch with my mag 360 a833 setup. Works well, has held up to lots of abuse and normal around town driving.
SCIENCE FRICTION Billet Steel Flywheel, SFI Quality, 130t/10.5", 360 Magnum, 6-bolt - American Powertrain
What pilot bearing do I need to go into my Magnum 5.9L stock crank with my A833?
Awesome, thank you! Yeah, I’m hoping I don’t have to cut mine either. It’s the original transmission to the car and I’m trying not to do anything irreversible in the future if by chance it ever gets restored. I’m also thinking about the American Powertrain hydraulic throw out bearing kit. Any thoughts?NATIONAL FC69907
I’ve heard of the input shaft length needing cut down a little bit too? I didn’t have to on mine after checking the clearance though.
I was just thinking about gaining header clearance. I plan on fabricating my own stainless 1 7/8” long tube headers and not having linkage would really just open up a lot of room. I’m going to install the engine with the bellhousing and see what the situation is room wise. Then I’ll make my decision.Honestly I’d stick with your stock linkage, if it’s all there since you’re using the stock Bellhousing. I have been reading into it recently, and I’ve seen varying reports of needing to modify the LH inner fender to clear the master cylinder. Despite this I plan on installing one of those kits or similar on my car when I go to a scatter proof Bellhousing.
Good news and bad news. My Icon pistons cam in. I dropped them off at the machine shop this morning and unfortunately just got a call from them. He weighed the original Magnum 5.9 STD bore pistons, rings, and pins and then weighed the Icon piston assemblies with the lightened pins and the lighter ring set was still 50 grams heavier than the originals. So now I’m looking at balancing the rotating assembly. Just sucks because I haven’t ordered my flywheel yet. Which means I’m delayed yet again at assembling this engine. I’m going to order the flywheel from American Powertrain I guess. Can anyone chime in on if this is correct. 130T, 10.5” clutch or do I need the 143T flywheel? I’ll be running the original bellhousing from the 340 that came with the car as well as the original 833 4-sped.
I need to get the flywheel ordered so I can get it and bring it with the balancer to the machine shop so he can balance the rotating assembly.
So I spoke with Brian at IMM about the piston weights. He was familiar with what I was talking about and assured me that the stock pistons are actually 40+ grams off balance and the new heavier pistons are actually much closer to balancing out on the stock crank. I’m might not be saying that correctly, but he assured me the Icon forged piston set up is more accurately in balance with the factory crank then the original cast piston assemblies and that no balancing is required. I believe what he is saying, but I still chose to have the rotating assembly balanced. I think its the best option with the engine completely torn down and so many new mixed components added. Should help it rev more freely and be easier on the bearings as well.Something doesn't sound right here. 50 grams is waay off. I would double check with IMMI and see what he thinks. Did you use the same rings and pins in
the magazine build? IIRC that build was with with .030 pistons so those would have been heavier yet?
The flywheel came in this morning so I took it in with the balancer to the machine shop. I should get everything back in a day or two so I can begin assembly. Keep an eye out for updates soon
That’s correct. Apparently the factory rotating assembly was way off balance and not spot on like you would assume it would be. Like I said though, I still went ahead and had my rotating assembly balanced. I just didn’t want to take a chance on what is turning out to be an all out engine build instead of the quick refresh I was originally thinking.So that would stand to reason that you could put a set of kb107s into a 5.9 mag with no need to rebalance.
5.9 mag - 469g piston 135g pin 604g total
kb107 - 524g piston 132g pin 656 total
52g difference
I’m glad you brought that up, I was just talking to a machinist buddy last night about that. I will be opening up the flange area and blending a radius into the opening below the flange. I’m going to gasket match the ports once the gaskets and heads arrive. I forgot to mention I filed the ring gap bigger so I can run some nitrous or boost in the future.Good to heat things are starting to move along for you. If thats the intake you are going to run you should look into having the carb flange turned into a true 4150 flange. Supposed to be a decent increase in power. Theres a few threads around here documenting this.
52g difference
That just shows how out of balance these engines were from the factory. Funny how your crank need weight added while mine needed weight removed. I'm just glad I spent the time and money to have it balanced, mostly for my own piece of mnd.I put KB 107's in my 5.9 mag, and mallory was needed and added to the crank.
