wildbill
They should be. It is pretty rich. But we didn't take the time to adjust it. I run a Sniper EFI in the truck. Mainly only running it on the dyno to make sure the oil leak was fixed.
They are not.Are the AFR readings in your dyno sheet accurate?
They are not.
The A/F ratio column on that sheet is derived from the data gathered from the air and fuel flow turbines.
If you look at the air flow column, the data is flatlined at about 283cfm.
That is obviously erroneous data.
So, any data that’s relying on the air flow numbers will also be erroneous.
On that sheet, that’s the air flow, a/f ratio, and VE
They are not.
That is obviously erroneous data, as air flow would climb as the rpm goes up.
On that sheet, that’s the air flow, a/f ratio, and VE.
I had assumed that the dyno was using O2 sensors! Learn something new every day.02’s are a whole ‘nuther thing.
I know enough about them to know they can lie to you.
But the OP’s sheet looks to be using the turbines for the A/F ratio.
Hell yea brother. 11s on wagon wheels!!
They can be either, or both.I had assumed that the dyno was using O2 sensors! Learn something new every day.
Of course modern muscle running 11.70s, or a lot faster is not uncommon.Thanks! Super fun truck.
I can't deny that I love the midnight grudge events. I take my 11 second stickers off the windshield.
Awesome if I end up against an import or modern muscle car.
