Got my dominator fuel log and air cleaner yesterday. I thought it’s a little weird that it’s plastic or so it seems. Also the Hughes max wedge port intake gaskets. Now just need my Indy SRs ported to the max. Kim
The heads are on the engine now. I have the Mopar M1 intake with MW ports. This combination has been on the engine since the build and dyno. No need to take it apart. Ran 131 mph in my 3250# 66 Valiant at 6800 rpms. First time I took the RPMs up it grenaded the 8.75. Dana 60 on the way.@66Valiant528 , do you have your stage 6 mw heads on your engine now ? i'm in a 540 build i have the stage 6 alum mw ports these were done by dave story in ky . did you ever try a mw intake with twin 750 fours on it , or hilborn fuel injection ? if you like we can pm this .
Sometimes stuff just works better than it should!
You know I just didnt have the money to buy the Chapman cnc heads at the time. I was a parts guy at a Mopar dealership and I got the parts at cost but it still took 20 years to build my car! Typical gear head, engine first.....reality is build the chassis first. But I was unaware at the time. Live and learn.My stage 6s are not mwp but he said the a Cindy SR is a better head. Those are the 2 sets I have so I’ll get the SRs opened up. Kim
Show off. Lol. KimView attachment 1715624602 these are my mw stage 6's View attachment 1715624603
Well I know you know what your talkin about!nope , just want you guys to know what i'm talking about here .
MW port. May be the same casting number. But againine were done by Dwayne and needed funky rockers.So then r ur heads better than the set I have or just the mw port? Kim
I needed the offset ones because of the port/pushrod intrusion. You must have the standard RB port. Nothing wrong with those heads. I've got a set of the MP aluminum 452 heads on my street 440 in my 68 Roadrunner. I believe they are just small chamber Eddy heads with straight peanut plugs.Mine have the standard blue MP rockers. Kim
The Edelbrock has angled plugs?I've got a set of the MP aluminum 452 heads on my street 440 in my 68 Roadrunner. I believe they are just small chamber Eddy heads with straight peanut plugs.
Definately straight plug and small plug.The Edelbrock has angled plugs?
Then this would be the reason MP desired straight plugs. Just like stock.
