SRT_DSTRHOLC
What are you guys running on your 6.1 intake setup for a throttle cable and how?
Thank You!
Thank You!
I deleted the extras. Geeez!How many threads do you think you need?
Really! That's just extra work for you!I deleted the extras. Geeez!
Ya, that's what I do for fun! LOLRe
lolYa, that's what I do for fun! LOL
Thanks, computer was acting up and never confirmed it postedI deleted the extras. Geeez!
That's because when you post multiple threads on the same subject within five or six minutes, it's very annoying. People will go out of their way not to answer. Disagree with every post all you want, I am simply telling you the truth.7 posts. Not one helpful on topic The waiting continues lol
I already comprehend that…. Do you think if i had known that i posted multiples that i wouldn’t have deleted them? Thanks for assuming my intelligence level.. and even if that’s the case of what others will assume and not help me… they don’t have to be a karen and reply anything. But, you did point out the fact before I noticed it, so thank you lolThat's because when you post multiple threads on the same subject within five or six minutes, it's very annoying. People will go out of their way not to answer. Disagree with every post all you want, I am simply telling you the truth.
I'm not assuming anything. I was simply letting you know that multiple posts about the same thing in a real short period might not be the best thing to get responses....and yet, here you are already insulting possible responding members calling them "karens". It's you who have assumed way too much, not I. We have some great members here who would be more than willing to help if you would drop the attitude. I wish you luck in your search for an answer.I already comprehend that…. Do you think if i had known that i posted multiples that i wouldn’t have deleted them? Thanks for assuming my intelligence level.. and even if that’s the case of what others will assume and not help me… they don’t have to be a karen and reply anything. But, you did point out the fact before I noticed it, so thank you lol
Noted. Will see what they have cooked upHave you given Bouchillon Performance a try? They have lots of specialty cables.
Thanks for the suggestion again. They have a kit with a bracket and cut to length cable. After this one I can just make them. Nice to have a templateHave you given Bouchillon Performance a try? They have lots of specialty cables.
Darn do you have a link to the cable kit?I am running a typical 92mm LS style throttle body with an LS throttle cable bracket and an adapter plate. The adapter bracket needed some slight shaving to make it all fit - not the prettiest or most "trick" set-up but was extremely affordable
Where did you get yours? Is it braided sleeve? This one from Bouchillon is crap. Hard plastic made for driver side throttle pull, gives no room to insert into firewall, plastic nipple on throttle cable side is too long. 150 down the toiletI am running a typical 92mm LS style throttle body with an LS throttle cable bracket and an adapter plate. The adapter bracket needed some slight shaving to make it all fit - not the prettiest or most "trick" set-up but was extremely affordable
Yeah. Lesson learned. Start with something cheaper and see if it works instead of working backwards. Can always buy the other on in the end, and again, I should have looked more carefully tooMine is also black hard plastic - there are universal ones available from Lokar and even cheap versions on Ebay that are braided
Hold for just a minute and I will take a pix of mine. It is serious farmenirring disclaimer!What are you guys running on your 6.1 intake setup for a throttle cable and how?
Thank You!
Will do! Thank yaOk, like you I searched everywhere I could for a graceful solution but as it goes for most aspects of the swap there is no real support yet, like the LS boys, so you end up fabricating yourself for the parts you need. I made these from a LS kit. Feel free to PM me if you need any other ideas for solving stuff. There is a bunch!
