Blah blah blah.....215 pounds of torque DOES NOT COMPARE to the torque output of a modern day diesel,, similar to the one in my Cehbby....600+ pounds of torque. Sure, if you gear the snot out of something it will move something, til you reach the failure point. 4.56 gears? Come on now, with no od and tall tires they aint very friendly. My diesel will easily pull 12k pounds......Is capable of easily hitting triple digit speeds....Can cruise at 90 mph with the car on the trailer behind it....
There is a small little hill not to far form me.....would pay to watch someone try to tow a car up it with a 2 + ton vehicle with a / in it......my Duramax with a 4" exhaust, programmer and air intake kit has to work to pull a car up it.....Folks can what you want, but here in the real world you need torque to pull things... My truck, when I had it dynoed right after I bought it, puts out a touch over 600 foot pounds of torque... does the / even get into the 3 digit zone when it comes to torque? Torque moves things, not wishful thinking....
yes the slant 6 has torque, but its also a very crappy truck engine, works great in small cars such as A bodies but thats about where it ends
can you imagine driving a 3 ton dump truck with a slant!
I've got a slant six 86 Ram W100 out in the drive that has done more work than most trucks. I've personally been witness to it plowing 4ft of snow and hauling beds full and overflowing of top soil, and numerious full bed loads of cut firewood. It was never short on power or torque with the 435, not to mention when needed the low range in 4wd.
I really wish the Ohio winters hadn't been so hard on the truck. The thing only has 32,000 miles on it which are verified, my dad bought the truck new. I'd love to fix the thing but I believe it's just too late.
One thing I'm not sure of is I was researching this thing a few months back and there are a few things about this truck that if you look at all information it shouldn't exist. Unless the information isn't correct.
Chrysler built PLENTY of trucks that "should not exist"! My friend's grandfather has one: 1976 W-300 extended-cab, 440/NP435/NP203, with factory A/C, camper package, and Sno-Commander package.
theres several Gen 1 4wd durangos with the v6. I've seen as many of those as I have the Dakotas out hereIf you think a s6 Ramcharger is odd, Have any of you seen a v6 Gen 1 v6 Durango, a chrysler warranty rep told me there actaully a hand full of 4 wd v6 Durangos built that way
Didn't Know you could get A/C and the sno-commander package, I'm assuming it doesn't have power steering.
Exactly my point! Note also: the NP203 was supposed to be only for automatics..
