6 or 12 Ton Hydraulic Press?
I have had my 15 ton press longer than HF has been around me. Doesn't have to be brand new to work. I walk in the local HF store once-twice a year and walk out as empty handed as I walked in ..
And about burning bushings I set them out on the gravel drive, lay the bottle torch next to the bushing and let it do the work. The burning black marshmallow is a little nasty but it works.
I've been doing what I have been doing, how I've been doing it for years and it just flat out works for me.
Maybe someday I'll make some fixtures to keep from squeezing the ears towards each other on the control arm but until then I'll do what has worked for me for many years.
Totally agree. The majority of my tools now are late seventies/early eighties Snap-on stuff from my old man’s business. I have a bunch of Craftsman “professional” series tools from the early 2000’s I bought new when I was building my own collection, when that particular model range was still US made. And if I have time to plan for a job I’ll look for vintage specialty Snap On stuff if I don’t have it.
You know, the 3/8” ratchet I use 90% of the time is from HF. Because it works better than the equivalent vintage Snap On and craftsman professional ratchets I have. Been using it for well over a decade, still my first choice. And totally by accident, I bought it to go in my tool bag for PickNPull so I wouldn’t trash/lose my good tools wrenching in the gravel, only to find it was a better damn ratchet then the stuff I had that costs several (or even many) times more. I broke the Craftsman professional grade ratchet I bought in under 5 years, and the rebuilt one Sears gave me to replace it was a POS.
The HF ratchet literally sits in a drawer next to Snap On and Craftsman professional series ratchets and the HF one is the one I use.
I used to burn out bushings. Does it work? Sure. Does it make your job harder? Yes, it absolutely does.
It’s a last resort that’s a total pain in the ***. I learned years ago it’s the dumbest way to do it, unless for some reason the job is so FUBAR that nothing else works. I can probably do the entire R&R job on the LCA bushings in the time it takes me to just burn out the bushing and then clean the mess.
There’s no “fixture” necessary. A short piece of 2” pipe is all you need. You should never attempt to press a UCA in a way where you’re compressing the ends of the arms together, that’s just wrong.
I know that's wrong, I have some tricks to keep that from happening
Funny. Hasn't been one yet. I do what I can, do what I have to with what I have
I used to buy all my tools at Sears and get craftsman brand. I used to enjoy going into Sears and looking at all the tools and thinking about Christmas. I never had a lot of money to buy tools, but when I did, I was very appreciative of having them. It was back in the 70s. Now if you want tools from a local store for your car for welding or anything else, Harbor freight has so much. Yeah they’re not top-of-the-line tools but if you’re only working on weekends and here and there, it’s good enough in fact I’m very appreciative to have harbor freight locally I can get pretty much anything I need there.
One last thought to leave with you. If you didn’t have Harbor freight and you needed some tools, where are you gonna go to get them? It’s not gonna be Lowe’s and it’s not gonna be Home Depot because they just don’t have many tools.
