mr.twister
Active Member
It was a Mopar,at the time of the original build,a f-steel crank was higher than nuts on a giraffe! These combos are very common now,so we built it back with a K-1.
Yeah, man!Well another "Myth" Busted that a 4" Cast Crank will break right away if you have over 500HP....... 1100 Passes, You got your $$ out of ANY ENGINE with that many runs!!. Well done! :cheers:
So which Cast Crank were you using??
I don't think 600 is a limit.. our dragster has a 2 bolt main 340 block.. a 10.7.1 iron w2 headed motor on bottle and has gone 7.28 @ 188 in the 1/4.. with a 325 horse hit that's probably 850ish HP and it hasn't came apart yet.. not to worried about it either.. no hard block is in the block either..
That is some crazy stuff right there..... Another Myth Busted. Think the weight may have something to do with it living??
Rod bolts and cylinder wall failures are the common problem. Rod bolts every two years at least. Never use any block over a 340-4. Castings on higher number blocks are poor quality. 340-8's are junk . The highest I have gone on a stock block that survived for 15 pulls was 593 @ 7200 CHP. The reason it came apart was poor maching work from Ryan. @ Shady Dell Speed shop.
Couple of years back. The only machine they had was a belt drive lathe and a harbor freight drill press mounted on concrete blocks for a mill. I gave them a bridge port That was wore out when I replaced mine. I wouldn't let them work on a briggs. They lied to me about every thing and stole my parts. They ended up having to replace every part they stole or ruined. Not even the intake was usable when they were done. the only thing that wasn't destroyed was the cam and that wasn't the one I gave them. Ryans brother left the cat out of the bag when I took my motor back in pieces. They also ruined a R3 with there so called lifter valley program done at another shop. They didn't have the block position in the center and pushed the go button. They tried to blame the block but a Rottler machine proved them wrong. They ended up paying me for all the parts but I lost the labor and other parts I gave them for His Car. It cost them a lot.
I pity those who don't don't Know he could sell ice to an Eskimo. I will never go back and wouldn't recommend them to anyone. If My son ever sees him anywhere there will be trouble. He the biggest liar I ever met in the mopar community. He talks the talk but doesn't walk the walk. Ray barton told me to stay away from him but I didn't listen. Rays shop was for a year.
One thing good came out of this is I met Dave at HTA machine AKA "The Hemi Hunter" Top fuel machinest. He did all of our race motors to date. Everything is done in house nothing is subbed out. Zero tolerance on all his work. My son is now a machinist at his shop and works on the Top fuel car.
Impressive...how many runs have you made with that combo on the spray?
my stock block is still going ,its getting on 2 bolt no girdle 3/4 fill car is 3550 lbs race weight its had 100 bottles of gas threw her here is a vid
9 92@135 full street trim - YouTube
angree ap6 - YouTube
Sweet, your car is cool as hell! I really like the back window shades!!
So Ian,
1) is yours a stroker combination?
2) How much NOS are you throwing at it.
3) Separate Fuel Pump for NOS?
4) What size rear tire and suspension set up?
man you got a list lol
1 ,408 4340 crank ,cheap h beams,probe flat top pistons 11.4 comp,1 3/4 pipes in to x pipe and twin 3 inch ,254 solid roller ,230 cnc indys and 1050 dom with powerglide 4.3 gears 4400 stall asp full exhaust tail pipes too 4 muffles to shut it up a bit 3550 lbs race weight 10.90 123 aspon pump fuel, she is slow but hit it with 180 shot and she comes alive ,rear tyres are mt 275 radial pro ,srange rear shocks cal trac mono leaf rear. i think i got it covered thanks mad dart
thanks mad dart,i run one aeromotive a 2000 pump 1/2 line and i spike the fuel on the gas for safety ,always willing to help mad dart :smile::burnout:Inquiring minds want to know!! LOL
1) So you run 1 fuel pump for the motor and NOS? Just curious.......
Thanks for all the information. Oh and your car is nowhere near slow on the motor with full exhaust. It runs HARD!
We'll I'm over the limit too fellas. 410 stroker all forged , solid roller 242@50 .634 lift at the valve Indy RHS Heads by Brian at IMM,, Smacking it with a 180 hit right now so that's close to 700HP if not over it. I bet the Torque is the same if not more on the Hit. I beat the **** out of it too. Let's see how long it lives. I'm putting a cage "Tubing is ordered" new race seats upholstered to match for the bling.... & 5 point harnesses in the car. I will be installing a second NOS system afterward...most likely 2nd stage will be a 300 Hit or so.... I'll sneak up on it.
Fck the police!:burnout:
do you actually race the scamp or just the light to light b.s.?
I actually drive my cars, every one of them. Since Friday I have burned 38 Gallons of fuel and went through 2 NOS Bottles. How about you? All my cars are Dual Purpose. But I am getting it ready for the Track since you asked.
You guys that track race crack me up, sitting in your garages starring at your cars working on them and go to the track 5 times a year calling yourself's Ricky Racer ..that gig is NOT for me. I will drive as much as I can and when it is ready it will go to the track as much or more than most. No sense in letting it ROT starring at it wishing you had enough $$ to get the parts to put it back together and get to the track with your 5 gallon jug of fuel, that is if you even have enough $ left over to buy it. Now that is BS to me! We can agree to disagree.
